Torsion bar install
#3172855
09/04/23 03:11 PM
09/04/23 03:11 PM
Posts: 1,176 clarks summit pa
73cuda340
clarks summit pa
I just finished installing the new torsion bar on the drivers side of my cuda and I noticed that between the end of the torsion bar and the groove for the retaining clip, there is approximately a 1/2" gap between the two. I don't remember there being this much space with the original bars. I also installed new QA1 lower control arms with the firm feel 1.06" bars and hotchkis adjustable strut rods, so I'm not sure if the gap is due to all of the new parts. I don't know if this is even an issue, however I'd rather ask while everything is still loose.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Torsion bar install
[Re: SportF]
#3172960
09/04/23 08:58 PM
09/04/23 08:58 PM
73cuda340
clarks summit pa
Ok thanks, just wanted to be sure
