Re: Electronic distributor gap
[Re: Sinitro]
#3172556
09/03/23 12:06 PM
09/03/23 12:06 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
0.008 using a brass feeler gauge.. Just my $0.02.. That seems about right from memory.
[Re: BlueRacer69]
#3172559
09/03/23 12:17 PM
09/03/23 12:17 PM
RapidRobert
I forget. Old age is sitting in. lol. Thanks. It'll get worse!
[Re: TJP]
#3172593
09/03/23 02:43 PM
09/03/23 02:43 PM
Posts: 10,735 North Dakota
6PakBee
North Dakota
I don't know about the MP distributor but I've run into a couple stock ones that as the vacuum advance moved the pickup plate, the gap decreased. I had one where the gap decreased to the point the reluctor contacted the pickup.
[Re: 6PakBee]
#3172615
09/03/23 03:53 PM
09/03/23 03:53 PM
Posts: 1,841 South Bend
John Brown
South Bend
I don't know about the MP distributor but I've run into a couple stock ones that as the vacuum advance moved the pickup plate, the gap decreased. I had one where the gap decreased to the point the reluctor contacted the pickup. Had the same situation years ago. Couldn't believe engineers didn't anticipate that happening. Aftermarket ball bearing breaker plates solved the problem.
[Re: 6PakBee]
#3172649
09/03/23 07:27 PM
09/03/23 07:27 PM
RapidRobert
I don't know about the MP distributor but I've run into a couple stock ones that as the vacuum advance moved the pickup plate, the gap decreased. I had one where the gap decreased to the point the reluctor contacted the pickup. years ago one of our members from south america (Nacho) did something to his advance plate to where he got the change down to several thou iirc to resolve that. not sure what he did but you might eyeball it & see if anything jumps out at you that you might alter that will decrease the change.. EDIT I am thinking that he just relocated the pivot point so there was less arc in the sweep
[Re: Rollin Hand]
#3172796
09/04/23 12:02 PM
09/04/23 12:02 PM
RapidRobert
^^^ this. find the one closest & set it at .008"
[Re: Rollin Hand]
#3172956
09/04/23 08:43 PM
09/04/23 08:43 PM
Posts: 732 Michigan
BlueRacer69
Take the distributor out of the motor. Spin the shaft and look for the smallest gap and go from there. That's good advice. Thanks for that information.
