This is a job best left to a machine shop to do, unless you have the tools to properly locate those holes.
Since you neglect to mention what van it is, I made an assumption and looked at rockauto.
LUK LFW219
PERFECTION CLUTCH 503413
Both new, both under $90.00, plus shipping and handling, both 143 tooth, both with the 360 imbalance holes.
If you are insistent in doing it yourself the drawing you want is probably in the MoParts tech archive. If not the old MP books have it or you could just google it like I did.
![[Linked Image]](https://hosting.photobucket.com/albums/v655/crackedback/Mopar%20info/360castbalance.jpg)
