69 GTS master cylinder??
#3172418
09/02/23 05:46 PM
09/02/23 05:46 PM
Posts: 25,957 United Socialist States of Ame...
tboomer
Guys...I think I need a new master cylinder for my 69 GTS 340. It has manual drums on it. The old one looks to be a 70 and on up. The pedal does not return all the way up...Ideas please..
Re: 69 GTS master cylinder??
[Re: tboomer]
#3172451
09/02/23 08:50 PM
09/02/23 08:50 PM
Posts: 20,661 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
They typically have part numbers cast into them on the bottom?. That would help us identify what you have.
If you want the correct number one for the car you may have to get an original and have it serviced. Otherwise one from the parts store for a drum brake application should plug right in.
If the car does not stop all that amazing you could also put some front disc brakes on it vs spending money on a drum master cylinder only to have to change it back out later?
[Re: gtx6970]
#3172477
09/03/23 12:33 AM
09/03/23 12:33 AM
Posts: 10,735 North Dakota
6PakBee
North Dakota
Almost all the drum brake master cylinders in the mid to late '60's seem to use the 2808606 repair package. I've had good luck (so far) rebuilding them with this equivalent kit: Dorman Kit
[Re: A12]
#3172570
09/03/23 12:48 PM
09/03/23 12:48 PM
Posts: 21,449 It's a dry heat
gtx6970
It's a dry heat
Looks like the same master cylinder that came on the '69 440 M-Code Darts with all around drum brakes. Exact same master cyl used on all 67 thru 1970 A , B and I think C bodies with drum brakes Ive used 2 of the repops linked and had zero issues
[Re: Cab_Burge]
#3172625
09/03/23 05:20 PM
09/03/23 05:20 PM
Posts: 43,590 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Only in 1967 were the big block GTS's and Barracudas manual 4-piston Kelsey Hays brakes. In 68 it was 4 wheel 10" drum with disc and power disc optional. The only rebuild master you can buy at all the parts stores nowadays are the 70-up Cardone with the wire cap hold down. Like said above, find a good core and get the rebuild kit, I have several originals laying around because of this...
JB Rhinehart, Realist
A-Body's RULE!
