Re: Small Tire Car Question
[Re: Dragula]
#3172030
09/01/23 10:44 AM
09/01/23 10:44 AM
Posts: 8,163 Plymouth, MI
Blusmbl
Plymouth, MI
Almost all places (except for Oklahoma, from what I understand) consider a 275/60/15 radial or a 28x10.5 non-W small tire. Some of the daily driver type classes will allow a larger metric tire, only if they're on a 17" or larger rim. My car has a 295/65/15 and has to race in big tire everywhere because it's 20mm too wide.
Radials require a different suspension setup, they like to be planted with separation and need to dead hook, and need tighter compression settings.
[Re: Blusmbl]
#3172033
09/01/23 10:47 AM
09/01/23 10:47 AM
Posts: 1,838 NW Indiana
fbs63
NW Indiana
Radials require a different suspension setup, they like to be planted with separation and need to dead hook, and need tighter compression settings. This in Indiana also. True 10.5 races used to be 29.5x10.5 but since the 275 classes gained popularity everything has gone to 28x10.5
[Re: fbs63]
#3172098
09/01/23 02:02 PM
09/01/23 02:02 PM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
What they said. Be careful of the height if going the 10.5 route. Most I've seen in the past seems to follow this, they still say 29 tall (for now), but it's changing. https://thenoprepnationals.com/rules/
Rich H.
Esse Quam Videri
[Re: GY3]
#3172102
09/01/23 02:20 PM
09/01/23 02:20 PM
Posts: 20,163 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Before you travel this road and start buying parts. Read the rules very carefully for the class as some mods will not be allowed
[Re: ZIPPY]
#3172127
09/01/23 05:21 PM
09/01/23 05:21 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
So many tracks or org's have different classes based on car build, type of racing event and tires.
There are dudes FLYING now on 235 drag radials, or 26x8.5 slicks.
Shocks are another story......several companies can design/build shocks for class rule specifics and/or personal purpose.
"Any fool can know. The point is to understand"
- A. Einstein
[Re: pittsburghracer]
#3172128
09/01/23 05:22 PM
09/01/23 05:22 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
Excellent advice.
- A. Einstein
[Re: justinp61]
#3173031
09/05/23 08:49 AM
09/05/23 08:49 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Around here nothing bigger than a 275/15 or a 28 X10.5 non W, a 325 will put you in big tire. Then there is the 235, 26 X 8 class, we don't see many here though. Same here. I run a 295-65 radial and there are a lot of classes my car doesn't fit b/c of the tire. I'd put a 275-60 on my car if it didn't look ridiculously small. It hooks fine on the smaller tire, just looks stupid to me. Even a lot of the street car classes won't allow anything bigger than a 275 or 28x10.5, which I think makes no sense. Like my 295-65 makes it a pro mod or something? Occasionally you'll see a class specifically for cars on a 295 or 29.5x10.5 slick, but they are few and far between. There are SOOO many options for a 275-60 or 28x10.5 tire car that I'd be hard pressed to set up a car for anything else.
[Re: an8sec70cuda]
#3173125
09/05/23 02:23 PM
09/05/23 02:23 PM
Posts: 4,564 Motor City
6PKRTSE
Motor City
Around here nothing bigger than a 275/15 or a 28 X10.5 non W, a 325 will put you in big tire. Then there is the 235, 26 X 8 class, we don't see many here though. Same here. I run a 295-65 radial and there are a lot of classes my car doesn't fit b/c of the tire. I'd put a 275-60 on my car if it didn't look ridiculously small. It hooks fine on the smaller tire, just looks stupid to me. Even a lot of the street car classes won't allow anything bigger than a 275 or 28x10.5, which I think makes no sense. Like my 295-65 makes it a pro mod or something? Occasionally you'll see a class specifically for cars on a 295 or 29.5x10.5 slick, but they are few and far between. There are SOOO many options for a 275-60 or 28x10.5 tire car that I'd be hard pressed to set up a car for anything else. Same for my car. I set it up to run 315's. It sits low already. With 28's it look ridiculous. Especially, with it stretched on to a 12" wheel.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: A727Tflite]
#3173267
09/06/23 08:20 AM
09/06/23 08:20 AM
an8sec70cuda
For you guys that have gone from these “small” tires to larger or vice versa, how much ET difference between the two? No real difference on my car b/t the 275-60 (28x10) and the 295-65 (30x10.5).
