Six Pack Metering plate conversion to use jets? #3171779
08/30/23 09:44 PM
08/30/23 09:44 PM
Shopping @ HoBo Fright
340SIX Offline OP
Doc Flappergas's Evil Twin
340SIX  Offline OP
I know Promax sells billet plates that take standard Holley jets. They also convert 4bbls too.
But see QFT and AED are they all.the same? Reason i ask is price point on the AED and QFT looks better.
Anyone use them?
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Six Pack Metering plate conversion to use jets? [Re: 340SIX] #3171808
08/31/23 06:00 AM
08/31/23 06:00 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I’ve used them both. Same quality on both.
Re: Six Pack Metering plate conversion to use jets? [Re: fastmark] #3171827
08/31/23 09:36 AM
08/31/23 09:36 AM
340SIX Offline OP
340SIX  Offline OP
Thanks if i am.unsure i now ask since so many things are junk now that were good before. It is good to know that the QFT amd AED will both work as good as the Promax.
You never know now days if even the Promax or anything is still good to go the way things are now.
Re: Six Pack Metering plate conversion to use jets? [Re: 340SIX] #3172512
09/03/23 09:12 AM
09/03/23 09:12 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Its amazing how far down the quality of some parts has descended. When doing a forum search on a product- a discussion here from as recent as 2019 may no longer be accurate as many manufacturers parts are now crap when maybe they were not a short few years ago.
Keep old mopars alive.
Re: Six Pack Metering plate conversion to use jets? [Re: 340SIX] #3172808
09/04/23 12:44 PM
09/04/23 12:44 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Make your own!! drill/tap. 10-32 tap
Re: Six Pack Metering plate conversion to use jets? [Re: R/T1968R/T] #3172831
09/04/23 01:56 PM
09/04/23 01:56 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Great idea R/T1968R/T . Seal all is a product designed to be completely submersed in gasoline- modern gasoline. Many think the standard JB Weld is gas proof. it is not and turns to goo.
Re: Six Pack Metering plate conversion to use jets? [Re: 340SIX] #3173013
09/05/23 02:01 AM
09/05/23 02:01 AM
I've drilled the stock holes that allow gas to get suck out of the bottom of the fuel bowls to fatten them up. I have a complete set of numbered drill bits from1 to 100 and a pin vise to put the smaller drill bits into use them in. I start with making the holes from.003 to .006 bigger, the driver sides holes are usually a little larger on the outboard carbs than the passenger sides are so I add to the stock size keeping the driver side bigger and then go drive it scope wrench up
I also have drilled and tap those holes for #6 brass set screws and then drill them, the blank brass set screws, to the size I want up scope
Another easier way of fattening them up is to restrict, reduce, the size of the high speed air bleeds to make them run richer also wrench up scope
I tune the center carb for light throttle pressure low RPM cruising under 3000 RPM wrench up
Re: Six Pack Metering plate conversion to use jets? [Re: 340SIX] #3173450
09/06/23 07:59 PM
09/06/23 07:59 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Or you can do this.....
