can anyone confirm if 72 Plymouth satellite rear frame rails.
72 Charger yes
73 Charger different part numbers than 72. They changed the springs in 73 to isolated rear springs and it may have affected the rear spring mounts but not positive this is the difference. They may still work fine. Not 100% sure on that one.
Yes same part numbers in 72 & 73
74 will work but has a large hump under the spare tire for an emissions compliant gas tank.
Different part numbers Satellite to Charger but are reproduced IIRC.
basically, rear clip? is the same as 72 / 73 dodge charger?
The core will work but some differences. If you are talented enough to swap the frame rails you are talented enough to make it work IMHO.
