Page 1 of 3 1 2 3
Location for Accusump #3171482
08/29/23 08:36 PM
08/29/23 08:36 PM
Illinois
gearhead01 Offline OP
Illinois
Hello All:
I am installing a 3 quart Accusump into a 1977 Roadrunner with a 440.
My original thought is to tuck it onto the area where the battery originally was. Will need to be at a compound angle, and attach with a mounting plate Going to be tight and may have issues with plumbing into the oil filter inlet adaptor.
Canton suggested possibly in the trunk, but that seems too far away to react quickly. I have see one in the passenger foot area inside the car, but i don't think that will pass tech.
Other areas I am looking at is mounted vertically in front of the radiator core support, or horizontally behind the front bumper.
Does anyone have some other place that they have mounted and Accusump?
Thank you, John
1971 Satellite Sebring Plus - 14.46 @ 95.43
1977 Road Runner - N/B 11.02@ 119 Drag Radials
Re: Location for Accusump [Re: gearhead01] #3171491
08/29/23 09:06 PM
08/29/23 09:06 PM
A727Tflite Offline
A727Tflite  Offline
Seen quite a few mounted in the front fender well - both horizontally and a few vertically just behind the front headlight area. Not familiar with your car’s fender well.
Re: Location for Accusump [Re: gearhead01] #3171493
08/29/23 09:10 PM
08/29/23 09:10 PM
AndyF Offline
AndyF  Offline
I have mine in the trunk behind the back seat. I use it as a pre-oiler and it works fine. I turn it on before cranking the engine over so I have oil pressure in the block before the crankshaft turns. Once the engine is running I turn the switch back off.
Re: Location for Accusump [Re: AndyF] #3171506
08/29/23 09:59 PM
08/29/23 09:59 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've usually seen them mounted to a fender apron, as close to the oil filter as workable.
Re: Location for Accusump [Re: gearhead01] #3171524
08/29/23 11:18 PM
08/29/23 11:18 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I had mine mounted right behind my shifter. Manual ball valve. NHRA chassis inspector didn’t like it, but said there were no rules against it. He said we let nitrous bottles and mechanical oil pressure gauges in the car, and thought that wasn’t a god idea either.
As far as distance… there is no difference in reaction. fluids don’t compress, so as long as there is oil in the line it will react immediately.
Re: Location for Accusump [Re: gearhead01] #3171528
08/29/23 11:30 PM
08/29/23 11:30 PM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
I mounted mine on the firewall.
Re: Location for Accusump [Re: TRENDZ] #3171529
08/29/23 11:35 PM
08/29/23 11:35 PM
Illinois
Illinois
Thank you for the ideas. I have looked in the fenderwells, and not enough room left as the frond strut bar passes through. The apron on an "F" body does not leave enough room either. Already tight with the 440 and 2" primary headers.
Still thinking about inside the car. I may take a trip down to Byron and talk to the Tech guy about it and areas inside, and also in front of the core support. The attached picture got me looking in this area.
Thahnk you again, John
Re: Location for Accusump [Re: gearhead01] #3171531
08/30/23 12:17 AM
08/30/23 12:17 AM
I have a 3 quart Canton brand I haven't used yet so I will probably end up mounting it as close as I can to the oil pump. wrench
I'm going to plumb it into the line from the remote mounted oil filter going to the block and use a T union fitting and use an electric switch to control it up scope
I'll probably end up using a switch that turns that switch on from the ignition circuit in case I forget to use it before starting the motor up wrench
Re: Location for Accusump [Re: gearhead01] #3171535
08/30/23 12:39 AM
08/30/23 12:39 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Here is my mock-up behind the driver's seat, understand, my oil cooler and remote oil/screen/filter are in trunk.
Note it has a manual shut off I can reach in addition to a solenoid valve and an inline one-way check valve, so as not to back feed into the remote filter.
The other lines are for trunk mounted tranny and diff coolers and temp senders.
Re: Location for Accusump [Re: gearhead01] #3171536
08/30/23 12:56 AM
08/30/23 12:56 AM
AndyF Offline
AndyF  Offline
Inside the car is illegal in NHRA but legal in NASCAR and SCCA. NASCAR runs the dry sump tank behind the driver's seat but NHRA doesn't allow liquids in the driver compartment. We hung the accusump on the rollcage inside the cabin on Tim's road race Valiant and that was fine with the road race tech guys but NHRA wouldn't allow it.
I will say that you don't want an aluminum tube full of hot oil inside the car on a street car. It is just like having a big heater sitting in the cabin with you. After 30 minutes or so the tank will be 180 degrees and the car will smell like hot oil!
Re: Location for Accusump [Re: AndyF] #3171542
08/30/23 02:15 AM
08/30/23 02:15 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
If the tank is filling repeatedly with running temp oil. it's a clear sign its working to some degree, and IMO something is amiss with oil pickup aspect of the oil system, and yes, this car will never see a 1/4 mile. grin
Re: Location for Accusump [Re: jcc] #3171543
08/30/23 02:24 AM
08/30/23 02:24 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
kinda off topic but has anyone used a FOA oil accumulator? https://f-o-a.com/shop/foa-oil-accumulator/
They are around for several years now and what I like about them (besides the low price of only $150) is that they come with an integrated electronic shut-off valve. No pressure gauge though.
Re: Location for Accusump [Re: DGS] #3171560
08/30/23 07:56 AM
08/30/23 07:56 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Doesn't say how much it holds. 3" x 18" body ... what would that hold ??
Re: Location for Accusump [Re: Stanton] #3171561
08/30/23 08:09 AM
08/30/23 08:09 AM
PA
moparacer Offline
moparacer  Offline
PA
One thing to consider. You should mount it somewhere that is fairly easy to access so it can be removed and cleaned during oil changes. I pull my Moroso off and clean it every change.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Location for Accusump [Re: moparacer] #3171576
08/30/23 09:46 AM
08/30/23 09:46 AM
Illinois
Illinois
Thanks guys - great discussion.
For now I am going to mount the solenoid valve near the oil filter area. I have a Canton control valve which is a little pricey, but has a mounting pattern in the end, and a port for the pressure sensor in the valve body. Don't need a tee for the pressure switch. Less fittings, lees places to leak.
It will give me time to find a place the the Accusump, and then just need to run the line to the valve inlet.
Plum Bad. I will look at the firewall when the engine is back in the car as a possibility.
Thanks again - John
Re: Location for Accusump [Re: moparacer] #3171578
08/30/23 09:48 AM
08/30/23 09:48 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Mine is going on the pass inner fender, line goes down to oil filter center hole the other hole will be plugged, on a 340. Electric shut off valve
Re: Location for Accusump [Re: cudaman1969] #3171587
08/30/23 10:52 AM
08/30/23 10:52 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Im not sure the distance really matters as an accumulator is a charged headspace in the running oil circuit so it should be constantly "on duty" and it should dampen even minute fluctuations in oil pressure.
Im actually more familiar with them in terms of industrial process control but I added one to my rocky and I love the added insurance. you can really tell a difference on the gauge that it's doing it's thing.
WIZE
In Car:
Re: Location for Accusump [Re: Stanton] #3171589
08/30/23 10:57 AM
08/30/23 10:57 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
volume is 2085cc = 2.2 quarts
calculated by the outside dimensions so in reality a little bit less and you also have to take into account that the accumulator cannot be 100% full as there will be compressed air inside as well. So I guess 2 quarts is the real value.
Re: Location for Accusump [Re: DGS] #3171590
08/30/23 11:06 AM
08/30/23 11:06 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
By the way the solenoid sold for the Moroso accumulators is a generic valve - nothing special about it other than the price.
Moroso electric valve $229: https://www.moroso.com/solenoid-valve23905/
Generic valve $40: https://ussolid.com/u-s-solid-3-4-b...lly-closed-viton-air-water-oil-fuel.html
available in stainless for $50: https://www.amazon.com/Stainless-Steel-Electric-Solenoid-Valve/dp/B00DQ24GS6
just need to search for the correct port size (I linked 3/4 but Moroso is 1/2 NPT)
Re: Location for Accusump [Re: DGS] #3171595
08/30/23 11:21 AM
08/30/23 11:21 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
An area of "real estate", if you will, is the front wheelhouse either for or aft of the wheel & tire.
I mounted a remote oil filter aft of the RF tire, at the side of the cowl, on my SB Duster (sig pic) racecar.
It had no splash shields, and 1 fenderwell header tube, ran the #10 hoses (fire-sleeved) through there to fittings @ the filter area (SBs having that on the RR of the block).
No stone damage in 25 years, but it was never on the street.
There's plenty of room forward of the tires, too, though you'd want the thing accessible.
Good tip from DGS: there are quite a few parts that go from generic to "race" courtesy of a decal... and huge markup.
Page 1 of 3 1 2 3
