Re: 440 rods in 383? [Re: JohnRR] #3171433
08/29/23 05:48 PM
08/29/23 05:48 PM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
Originally Posted by JohnRR
Originally Posted by Streetwize
But if I was using an LY or similar oem rod with a 1.09 pressed pin, i would definitely do the old Landy trick and whack 1/2" off the pin and save about 50 grams per slug. you're gonna have to re-balance anyway so why not take out weight instead of add it back?
Something like that never even crossed my mind ... now I'm going to have to take the 383 that Dan did for me apart ...
Have to use Delrin plugs or the like to keep the pins where they belong after shortening the pins?
Re: 440 rods in 383? [Re: John Brown] #3171449
08/29/23 06:32 PM
08/29/23 06:32 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
Pressed pins
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: 440 rods in 383? [Re: John Brown] #3171459
08/29/23 06:57 PM
08/29/23 06:57 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The more modern solution would be to get some thin wall pins that match your pistons required length. Too short of a pin puts too much load and stress on a part of the piston it is not designed to take.
Re: 440 rods in 383? [Re: HotRodDave] #3171474
08/29/23 08:10 PM
08/29/23 08:10 PM
A727Tflite Offline
A727Tflite  Offline
Any part of the pin sticking out past the pin tier adds virtually nothing to pin or piston durability. Thin pins actually put more load in to the pin tiers. New pistons designed for thin pins are reinforced in this area. Taking a production piston and installing thin pins in will eventually crack the pin tiers. Only a matter of time and cycles.
Re: 440 rods in 383? [Re: JohnRR] #3171479
08/29/23 08:31 PM
08/29/23 08:31 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted by cudaman1969
Originally Posted by Cab_Burge
How about finding a decent 440 crank and have the mains turned down to B size and have the crank offset stroke to BB Chevy size and increase the stroke to 3.91 and use some after market BB Chevy H or I beam rods 6.8 or 6.7 long to really wake that Super Bee up whistling stirthepot up devil
I do that to some of my milder 400 blocks I build for customers who want to do a low deck build a little cheaper than going with a new stroker crank, rods and pistons up work scope twocents
I’d bore the main bores out to 440 size, more crank choices out there
That's a bad move in a 383 block , the main webbing is already paper thin.
I’ll check that but doubt it
Re: 440 rods in 383? [Re: JERICOGTX] #3171538
08/30/23 01:08 AM
08/30/23 01:08 AM
PA
Scully Offline
Scully  Offline
PA
Standard bore 1.93 CH 440 pistons with 383 Eagle rods are your best bet for a street cruiser, all that other stuff is a waste of money. The longer rod ratio will only hurt the low end torque as well as the V to P clearance.
Re: 440 rods in 383? [Re: Scully] #3171606
08/30/23 11:56 AM
08/30/23 11:56 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Bore of the 383 is 4.250 , 440 is 4.320 , that's .070 over , sonic checker is your friend ...
Re: 440 rods in 383? [Re: cudaman1969] #3171607
08/30/23 12:00 PM
08/30/23 12:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
look at this ...
linky
Re: 440 rods in 383? [Re: A727Tflite] #3171629
08/30/23 01:05 PM
08/30/23 01:05 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Nobody is talking about pin sticking out past the piston, anything sticking out past the piston is useless and should be removed and it is only possible on pressed pistons, we're talking about floating pins and others have mentioned even putting something between the end of the shorter pin and the clip...
A modern high strength thin wall pin if sized properly can flex less than an ancient heavy stock pin. If you run one made of tin foil that is on you.
Re: 440 rods in 383? [Re: JohnRR] #3171993
09/01/23 01:44 AM
09/01/23 01:44 AM
PA
Scully Offline
Scully  Offline
PA
I've done many of them, the extra .005" per side over a .060" over isn't going to make any difference. I have a sonic tester and I haven't bored one yet that was anywhere near the danger zone, I'm sure there are some thin ones but I've never run across them and think they are probably the exception..
Re: 440 rods in 383? [Re: Scully] #3173591
09/07/23 03:00 PM
09/07/23 03:00 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
Great Timing!
I have a smoked 383 crank with a decent block and was thinking about having it turned down to 2.2 rods to use BB Chevy rods. I had a 458 back in the day that used BB Chevy 6.80 rods and 1.32 pistons to get all the compression in a 400 block. That engine ran great.
I noticed BB Chevy pistons had the right bore for a 383 but wasnt sure if it would work. I can hear my engine builder now...lol.
I would love to hear more about this if some has tried it.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: 440 rods in 383? [Re: JERICOGTX] #3173605
09/07/23 03:56 PM
09/07/23 03:56 PM
AndyF Online content
AndyF  Online Content
Did it years ago with a buddy's Duster. We used long rods and custom pistons to build some compression. It had Edelbrock RPM heads ported by Dwayne and a small Ultradyne solid roller (236/236). That sucker ran hard! Made 600 hp and pushed his mostly stock Duster into the 10's on street tires with full exhaust, full interior, etc. No rollbar, nothing. Just went to the track, ran some 10's and got kicked out. He drove that car to work for a few years and then got married and sold it.
Re: 440 rods in 383? [Re: AndyF] #3173760
09/08/23 11:26 AM
09/08/23 11:26 AM
Johnstown
69dart Offline
69dart  Offline
Johnstown
Andy - I think my 458 crank was from you waaaay back in the day (2001ish).
As far as know that engine is still running 10.50's in NSS.
68 Dart - 340
66 Belvedere - 400
Re: 440 rods in 383? [Re: 69dart] #3174401
09/11/23 12:59 PM
09/11/23 12:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by 69dart
Great Timing!
I have the Enginemasters crank with 6.7 rods and 1.32 pistons. The 1.32 pistons can be used with a number of different stroke/ rod combos. works wit ha 3.75 stroke , 3.9 stroke and a 4.25 stroke. I'm thinking of upping the stroke on the 383 stroker I'm doing now to 4.25 , just need a 6.535 rod.
The one issue you may have is the valve reliefs on the BB chevy piston may not work with your wedge head mopar configuration , might be easier to just buy a mopar piston.
Re: 440 rods in 383? [Re: JohnRR] #3174415
09/11/23 01:47 PM
09/11/23 01:47 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I looooong time ago I had a stroked 383 (440 Crank) built from a low compression 454 chevy truck piston and a LY rod bushed to .990.
I'm thinking the compression height was 1.4 something.
We did all kinds of crazy Frankenstein stuff back in the day....because we had to.
But that little '383' (431) ran stout with a Racer Brown cam and a street dominator and some ported 915's. I don't think we had any P/V issues
WIZE
In Car:
Re: 440 rods in 383? [Re: Streetwize] #3174461
09/11/23 03:47 PM
09/11/23 03:47 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The math says zero deck would be 1.337 , I'm finding pistons with a 1.395 CH and a single valve relief in a weird spot.
logged in the memory bank for future use ???
Re: 440 rods in 383? [Re: JohnRR] #3174502
09/11/23 05:22 PM
09/11/23 05:22 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Yeah I think we whacked at least .030 of the top of the BBC slugs, they were OEM (maybe what? 7.8:1) 454 slugs straight out of a junked mid 70's suburban.
We tried to do the math to make a 383 rod work but there was nothing even remotely close. I think we ran .060 copper head gaskets, it was definitely a frankenstein but it ran like a scalded ape.
WIZE
In Car:
