Having had a welding shop that repaired rusted frames, the hard reality is that frame may or may not be able to be fixed. It really depends on where the rust problem was located on the frame, and how bad it really was. If it was repairable and she drove it until it broke, its probably done for.
The word is, the Dakota frame was the same (provided you match cab to cab, and bed length to bed length) from the 1989-2003 (or when ever the truck changed at that time frame). Each cab and each bed length had a different wheel base. The 2 wheel drive frame is completely different then the 4x4 frame, not much interchanges between the two past the sheet metal and the drive trains themselves, but each drive has the mounts for the frame used.
Realistically, at 170K miles, she has a parts truck. Swapping the frame, unless you can do it all yourself, is not cost effective, and at those miles, the drive train is near the point of needing to be rebuilt. That sheet metal better be spotless and clean (looking at the front cab mounts and the driver side floor pan under your feet, are good starting points to determine if the sheet metal is worth moving to a different frame). I'm betting your sister is in a position of needing to buy a different vehicle.
I bought a 96 Dakota 4x4 with 44,000 miles on it for $400 because you could crumble the frame with your fingers. I moved the drive train to a different 4x4 frame, and put an old truck body on it. I've done several of these Dakota frame swaps under different vehicles. This 4x4 took 2200 hours, that is 11 months of 9-5 hours of actual labor time, at a fully equipped shop with an experienced worker, and around $8,000 in parts to get it road worthy. That was before I started on the body and paint work. Had I put another Dakota sheet metal on that frame, both the cost and the time frame may have been cut in 1/2, still pretty expensive and time consuming..
