Swirl scratches on glass #3171108
08/28/23 02:18 PM
08/28/23 02:18 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Hey Moparts Community!!!
I have what I can see and tell is swirl marks on my glass, it's on the outside for sure. It appears to be that someone has tried to use a wheel and compound to get hard water spots off the glass. and has pardon my french F***ed up all the glass. is there a way to somehow get this out so the glass doesn't have this hazy look to it.
or am i going to have to replace all the glass just like all the other small details I am trying to correct on the car.
thanks for the advice. I tried to take a picture, but it doesn't show up in photos.
Thank you
Kiddart
Re: Swirl scratches on glass [Re: Kiddart] #3171118
08/28/23 02:47 PM
08/28/23 02:47 PM
Rio Linda, CA
John_Kunkel Offline
The Erection Connection
John_Kunkel  Offline
Rio Linda, CA
Sounds like somebody incorrectly used a glass polishing kit. The trick with these is to never let the polishing disc go dry, keep the abrasive wet wheel wet. Lots of YouTube videos.
https://glasspolishshop.com/glass-r.../windscreen-polishing-kit-do-it-yourself
Re: Swirl scratches on glass [Re: John_Kunkel] #3171139
08/28/23 04:14 PM
08/28/23 04:14 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I will order and give it a try, I think the trick to fixing is keeping the compound wet.
I will keep you all posted on my results.
Thank you
Kiddart
Re: Swirl scratches on glass [Re: Kiddart] #3171166
08/28/23 05:10 PM
08/28/23 05:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Could also be the glass was dirty and all they did was grind that dirt against the glass.
I've used a buffing wheel over glass plenty of times without scratching it, but everything was clean.
Ironically, that won't work to get rid of scratches, but like paint, it can sure install them.
