Re: Fellow Engine Builders: Low RPM Cold Knock [Re: BigDaddy440] #3170956
08/28/23 03:19 AM
08/28/23 03:19 AM
California
BigDaddy440 Offline OP
California
UPDATE!
First, thank you to all who offered suggestions. This really had me stumped. Many of you mentioned the flywheel / flex plate.
Below is a 2 minute video update showing exactly where the nose was coming from.
https://youtu.be/GZzx_uC7blU?si=cxSEXEHNUw8upIj_
For those who would prefer reading:
The flywheel bolts (not converter bolts) ended up being too long, but long enough that it wasn't noticeable to the eye. They torqued down to spec, but were actually bottoming out in the crankshaft and not pressing against the flywheel hard enough to secure it while running.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Fellow Engine Builders: Low RPM Cold Knock [Re: BigDaddy440] #3171034
08/28/23 11:17 AM
08/28/23 11:17 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Thanks for the update! Glad you found it. beer
Re: Fellow Engine Builders: Low RPM Cold Knock [Re: slantzilla] #3171072
08/28/23 01:10 PM
08/28/23 01:10 PM
moparx Offline
moparx  Offline
great find. up
beer
Re: Fellow Engine Builders: Low RPM Cold Knock [Re: BigDaddy440] #3171085
08/28/23 02:05 PM
08/28/23 02:05 PM
A727Tflite Offline
A727Tflite  Offline
Originally Posted by BigDaddy440
UPDATE!
Never seen a Mopar without through holes on the crank flange.
Re: Fellow Engine Builders: Low RPM Cold Knock [Re: A727Tflite] #3171088
08/28/23 02:11 PM
08/28/23 02:11 PM
UPDATE!
iagree up
They were working on Chevy, probably didn't need to post it on here.
I sincerely hope they repalced that flex plate, it had way much clearance and movement between the flexplate bolts bolt to flexplate fitment twocents work It should not rotate like it did tsk work
Re: Fellow Engine Builders: Low RPM Cold Knock [Re: Cab_Burge] #3171090
08/28/23 02:13 PM
08/28/23 02:13 PM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
Id ask on a stockish looking build or parts, why not just use oem flywheel bolts vs aftermarket and costly. OEM stuff is pretty tough and proven.
STOP POTATO HATE!
Re: Fellow Engine Builders: Low RPM Cold Knock [Re: Cab_Burge] #3171128
08/28/23 04:33 PM
08/28/23 04:33 PM
A727Tflite Offline
A727Tflite  Offline
UPDATE!
iagree up
Guilty as charged - not reading the first post.
Re: Fellow Engine Builders: Low RPM Cold Knock [Re: BigDaddy440] #3182894
10/10/23 09:07 PM
10/10/23 09:07 PM
JACKSONVILLE
P
Pealer Offline
Pealer  Offline
P
JACKSONVILLE
Did the bolts solve the issue?? I've been following this thread for a couple weeks but just now registered to be able to see the replies, and I watched the vid and read the description. No idea if this is the issue I'm dealing with but it will be the first culprit once I get under the car to check things out. Thanks for the updates!!
