Re: dial back vs D cell timing light [Re: Diplomat360] #3163429
07/26/23 03:59 PM
07/26/23 03:59 PM
S.W. Pennsylvania
markrr Offline
markrr  Offline
S.W. Pennsylvania
Originally Posted by Diplomat360
Using a digital dial-back light here - INNOVA 3568.
The nice thing is that with a quick push of a button I get multiple functions: RPM, Timing, Dwell, all in a convenient display.
Makes for easy idle check, followed by RPM rise to see when the rest of the mechanical advance curve kicks and is all in. Appears to be spot on, it matched my old dial-back light.
I just got one of these. I haven't used it yet.
Re: dial back vs D cell timing light [Re: Diplomat360] #3165708
08/05/23 09:51 AM
08/05/23 09:51 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Innova is the same dial back i have. I found a penske light , but it does not have the inductive pick up clamp, so will have to find my dads old sears and then can compare all 3 light using an external 12v battery.
Re: dial back vs D cell timing light [Re: mopar dave] #3170940
08/27/23 10:57 PM
08/27/23 10:57 PM
Mt Morris Michigan
Mt Morris Michigan
Found my dads old sears timing light and decided to do a comparison between the D cell, sears, Innova dial back and an inexpensive no name light. All of the 12v lights were connected to an external 12v battery. They all gave the exact same readings at idle and at full total timing. Decided to try the sears connected to the car on board voltage. What i found was that as i increase the RPM timing would retard a total of 5 degrees at 3000-3500rpm. Connected the sears to the external battery and retard with RPM is only 1 degree. Same results with the D cell, 1 degree retard total. I did not check the other 2 lights this way. I would suggest always connecting to an external battery when setting timing or get a D cell light. My connection on the car was the battery side of the start relay and ground. Dont know why this happens, but it does.
Re: dial back vs D cell timing light [Re: mopar dave] #3171014
08/28/23 10:20 AM
08/28/23 10:20 AM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
I like the simplicity of my D cell light but I wish it was brighter. Don't forget to take the batteries out when you are not using it for a while. Don't want corrosion to kill it. Costs a lot more than a flashlight.
Re: dial back vs D cell timing light [Re: mopar dave] #3171610
08/30/23 12:16 PM
08/30/23 12:16 PM
Mt Morris Michigan
Mt Morris Michigan
I tested the other 2 timing lights connected to my starter relay just to be sure everything was i thought and sure enough all the 12v lights retard timing connected to car 12v supply. It looks like the more rpm you give it the more it retards. I was seeing 5 and 6* retard. Connected the external battery, 1* retard and same for the D cell light. Was also seeing spark scatter and timing mark disappearing after 3500, but it seemed to be the inductive clamp picking up signal from the other plug wires. All is well and gonna leave it at 33* total form now. Not sure how much i'm giving up at this setting, but will test it next time out.
Re: dial back vs D cell timing light [Re: GomangoCuda] #3171614
08/30/23 12:27 PM
08/30/23 12:27 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
iagree Just recently (couple of years ago) switched to a Batt operated Timing light for the race trailer. Makes thing much quicker and convent
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: dial back vs D cell timing light [Re: W.I.N. Racing] #3171792
08/30/23 11:07 PM
08/30/23 11:07 PM
Mt Morris Michigan
Mt Morris Michigan
I think the D cell battery operated light could be any racers best friend. I just wish it had a brighter strobe.
Re: dial back vs D cell timing light [Re: mopar dave] #3171942
08/31/23 07:34 PM
08/31/23 07:34 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Dave , do you have a crank trigger on your car ? I just tried my Snap On light & it does not retard . Yes I have a crank trigger . Gary
Re: dial back vs D cell timing light [Re: Gabby63] #3172018
09/01/23 09:40 AM
09/01/23 09:40 AM
Mt Morris Michigan
Mt Morris Michigan
No, i do not and i have a curve in the distributor. I did fix an issue like this on a small block a few years back by adding a crank trigger. It seems my car wiring is doing something odd to the pick up in the distributor. Not everyone has this issue, but i think some do with all the discussions about retarded timing while increase rpm i used to read on this board years back.
Re: dial back vs D cell timing light [Re: mopar dave] #3172023
09/01/23 10:11 AM
09/01/23 10:11 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
It is an inherent thing that electronic ign's do. some types more than others.
