Leakdown Testers #3170243
08/24/23 08:52 PM
08/24/23 08:52 PM
oklahoma
forphorty Offline OP
oklahoma
I would be interesting in hearing everyone's preferences as far as brand/model. I'm not a professional and this tool probably won't get used very often.
Re: Leakdown Testers [Re: forphorty] #3170251
08/24/23 10:02 PM
08/24/23 10:02 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Been using a Moroso for years.
Re: Leakdown Testers [Re: forphorty] #3170283
08/25/23 01:18 AM
08/25/23 01:18 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I have a snap-on for 30 years. You can buy or even make a cheap one, lots of Youtube videos. Ebay has them for $35.00 https://www.ebay.com/itm/304592254582?chn=ps&_trkparms=ispr%3D1&amdata=enc%3A1txWD82BQSpO5rMr5kUpOBg18&norover=1&mkevt=1&mkrid=711-213727-13078-0&mkcid=2&itemid=304592254582&targetid=4580840332323346&device=c&mktype=&googleloc=&poi=&campaignid=441131611&mkgroupid=1235851352595866&rlsatarget=pla-4580840332323346&abcId=9300906&merchantid=51291&msclkid=7aeab19b263d12d5d47fd5731e906035
No real moving parts just pressure regulator, two gauges, and a fixed orifice.
Re: Leakdown Testers [Re: forphorty] #3170285
08/25/23 01:35 AM
08/25/23 01:35 AM
FAA approved dual gauge aircraft tester from Aircraft Spruce is what I use now after using a Moroso single gauge for years up
Re: Leakdown Testers [Re: Cab_Burge] #3170287
08/25/23 05:55 AM
08/25/23 05:55 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Dual guage Snap-on for many years. Never had an issue.
Re: Leakdown Testers [Re: Cab_Burge] #3170336
08/25/23 11:33 AM
08/25/23 11:33 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Never used one. Better? More accurate? More precise? More repeatable?
If it's better, I'm interested.
Re: Leakdown Testers [Re: forphorty] #3170343
08/25/23 11:48 AM
08/25/23 11:48 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I bought the summit house brand years ago , does the job for me , like you I'm not a pro and I think friends have used it more than me .
Re: Leakdown Testers [Re: Cab_Burge] #3170356
08/25/23 12:36 PM
08/25/23 12:36 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Cab, it seems that aircraft air leaked at 70psi when most cars are tested at 100psi.
Any reason for that?
Thanks,
Bill
Re: Leakdown Testers [Re: JohnRR] #3170359
08/25/23 12:39 PM
08/25/23 12:39 PM
PA
moparacer Offline
moparacer  Offline
PA
I have a MAC I bought off the tool truck probably 20 years ago or so.
I would just buy a lisle off of Amazon for $30 if you aren't going to use it a lot.
https://www.amazon.com/Cylinder-Lea...;hvtargid=pla-4584482475463938&psc=1
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Leakdown Testers [Re: 340Cuda] #3170377
08/25/23 01:36 PM
08/25/23 01:36 PM
Most of the leak down meters I've seen and used call for 80 lbs., not 100 shruggy
My air compressor kicks on at 75 lbs. and shuts off at 125 lbs. so when it kicks on so I have wait until it shuts off to continue testing up
I set the pressure on every cylinder to make sure I'm getting semi accurate results, you can rock the crankshaft a couple of degrees with air pressure in the cylinders, not to many degree though tsk whistling and see a change, especially on a cold motor scope wrench grin
Re: Leakdown Testers [Re: Cab_Burge] #3170387
08/25/23 01:57 PM
08/25/23 01:57 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Yep. Single gauge tool needs to have the regulator adjusted every hole.
Two ways to do this. Set it on TDC - valves closed - and check it, or plug the hose in, bar the engine over until it hits the compression, give it an extra push and hold it steady until the gauge settles.
Seen both used by pros. One better than the other?
Re: Leakdown Testers [Re: jwb123] #3170414
08/25/23 03:45 PM
08/25/23 03:45 PM
moparx Online content
moparx  Online Content
Re: Leakdown Testers [Re: moparx] #3170436
08/25/23 05:15 PM
08/25/23 05:15 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I got mine from Summit over 30 years ago and test at 100 pounds. One of the reasons I bought a 2 stage compressor.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Leakdown Testers [Re: pittsburghracer] #3170456
08/25/23 07:11 PM
08/25/23 07:11 PM
oklahoma
oklahoma
Thanks for the info guys. It sounds like there may not be much difference in quality between the various brands .
Re: Leakdown Testers [Re: CMcAllister] #3170503
08/25/23 10:49 PM
08/25/23 10:49 PM
FAA certified A&P mechanics do it with the piston down low on the firing stroke and then use the prop to rotate the crank and piston back up to get it sealed up and read what their gauge says, not real precise but they are making the FAA happy by using that method shruggy work
I'm trying to remewmber the cutoff reading for failing the FAA guidelines, I'm thinking 70 % leakage was still flyable for another year on several cylinders(2 out of six shock) puke
I would go fly my plane for twenty + minutes before doing any engine tesing on compression, those air coll motors are really loose on the clearances shruggy
Re: Leakdown Testers [Re: Cab_Burge] #3170531
08/26/23 09:09 AM
08/26/23 09:09 AM
PA
moparacer Offline
moparacer  Offline
PA
I warm engine, put it on TDC and hook up tester. Adjust inlet pressure to 100 PSI. Look at cylinder gauge. Subtract whatever it reads from the 100 PSI. That is your leak down percentage. Continue through firing order to do rest of cylinders.
Re: Leakdown Testers [Re: jwb123] #3170534
08/26/23 09:38 AM
08/26/23 09:38 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
"Please note: This cylinder leak tester is not suitable for shallow cylinder."
Never heard this term before. What is a shallow cylinder?
Re: Leakdown Testers [Re: forphorty] #3170542
08/26/23 10:00 AM
08/26/23 10:00 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
I bought one recently, just a cheap Sealey one. Compression test said it was low on #3. I thought it was just a cylinder head gasket. The thing with a leakdown test is you can narrow down where your issue is when you locate where the air is escaping from, for example exhaust or inlet valve, gasket, rings or bore.
We had air escaping from the breather, 100% leakdown so I thought maybe we'd nipped a ring ? Fault is below.
Re: Leakdown Testers [Re: Tig] #3170567
08/26/23 12:02 PM
08/26/23 12:02 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
It may not be correct but I always set the gauge (dual gauge) to 100, connect it to the cylinder that is at TDC and bring it back up to 100 psi.
It makes the math easy on the leakdown percentage.
Sometimes I do have to trip the compressor to get back up to over 100 psi.
Probably the most important is that I do it the same way and record the results.
Re: Leakdown Testers [Re: 340Cuda] #3171309
08/29/23 11:30 AM
08/29/23 11:30 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Had and used OTC for years with no issues.
