Re: Leakdown Testers
[Re: Cab_Burge]
#3170336
08/25/23 11:33 AM
08/25/23 11:33 AM
Posts: 11,649 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
FAA approved dual gauge aircraft tester from Aircraft Spruce is what I use now after using a Moroso single gauge for years Never used one. Better? More accurate? More precise? More repeatable? If it's better, I'm interested.
[Re: forphorty]
#3170343
08/25/23 11:48 AM
08/25/23 11:48 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
I bought the summit house brand years ago , does the job for me , like you I'm not a pro and I think friends have used it more than me .
[Re: Cab_Burge]
#3170356
08/25/23 12:36 PM
08/25/23 12:36 PM
Posts: 3,525 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
FAA approved dual gauge aircraft tester from Aircraft Spruce is what I use now after using a Moroso single gauge for years Cab, it seems that aircraft air leaked at 70psi when most cars are tested at 100psi. Any reason for that? Thanks, Bill
[Re: 340Cuda]
#3170377
08/25/23 01:36 PM
08/25/23 01:36 PM
Posts: 43,263 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3170387
08/25/23 01:57 PM
08/25/23 01:57 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Yep. Single gauge tool needs to have the regulator adjusted every hole. Two ways to do this. Set it on TDC - valves closed - and check it, or plug the hose in, bar the engine over until it hits the compression, give it an extra push and hold it steady until the gauge settles. Seen both used by pros. One better than the other?
[Re: moparx]
#3170436
08/25/23 05:15 PM
08/25/23 05:15 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I got mine from Summit over 30 years ago and test at 100 pounds. One of the reasons I bought a 2 stage compressor.
[Re: CMcAllister]
#3170503
08/25/23 10:49 PM
08/25/23 10:49 PM
Cab_Burge
Yep. Single gauge tool needs to have the regulator adjusted every hole. Two ways to do this. Set it on TDC - valves closed - and check it, or plug the hose in, bar the engine over until it hits the compression, give it an extra push and hold it steady until the gauge settles. Seen both used by pros. One better than the other? FAA certified A&P mechanics do it with the piston down low on the firing stroke and then use the prop to rotate the crank and piston back up to get it sealed up and read what their gauge says, not real precise but they are making the FAA happy by using that method I'm trying to remewmber the cutoff reading for failing the FAA guidelines, I'm thinking 70 % leakage was still flyable for another year on several cylinders(2 out of six ) I would go fly my plane for twenty + minutes before doing any engine tesing on compression, those air coll motors are really loose on the clearances
[Re: Cab_Burge]
#3170531
08/26/23 09:09 AM
08/26/23 09:09 AM
Posts: 2,521 PA
moparacer
PA
I warm engine, put it on TDC and hook up tester. Adjust inlet pressure to 100 PSI. Look at cylinder gauge. Subtract whatever it reads from the 100 PSI. That is your leak down percentage. Continue through firing order to do rest of cylinders.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: jwb123]
#3170534
08/26/23 09:38 AM
08/26/23 09:38 AM
Posts: 10,749 North Dakota
6PakBee
North Dakota
I have a snap-on for 30 years. You can buy or even make a cheap one, lots of Youtube videos. Ebay has them for $35.00 https://www.ebay.com/itm/304592254582?chn=ps&_trkparms=ispr%3D1&amdata=enc%3A1txWD82BQSpO5rMr5kUpOBg18&norover=1&mkevt=1&mkrid=711-213727-13078-0&mkcid=2&itemid=304592254582&targetid=4580840332323346&device=c&mktype=&googleloc=&poi=&campaignid=441131611&mkgroupid=1235851352595866&rlsatarget=pla-4580840332323346&abcId=9300906&merchantid=51291&msclkid=7aeab19b263d12d5d47fd5731e906035
No real moving parts just pressure regulator, two gauges, and a fixed orifice. "Please note: This cylinder leak tester is not suitable for shallow cylinder." Never heard this term before. What is a shallow cylinder?
[Re: forphorty]
#3170542
08/26/23 10:00 AM
08/26/23 10:00 AM
Posts: 2,933 A shed in England
Tig
A shed in England
I bought one recently, just a cheap Sealey one. Compression test said it was low on #3. I thought it was just a cylinder head gasket. The thing with a leakdown test is you can narrow down where your issue is when you locate where the air is escaping from, for example exhaust or inlet valve, gasket, rings or bore. We had air escaping from the breather, 100% leakdown so I thought maybe we'd nipped a ring ? Fault is below.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: 340Cuda]
#3171309
08/29/23 11:30 AM
08/29/23 11:30 AM
Posts: 19,379 Las Vegas
Al_Alguire
Las Vegas
Had and used OTC for years with no issues.
