Page 4 of 8 1 2 3 4 5 6 7 8
Re: New clutch, SEVERE Chatter from a stop NOW WITH PIC's [Re: Sniper] #3168865
08/18/23 04:06 PM
08/18/23 04:06 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
Originally Posted by Sniper
Originally Posted by TJP
Sniper Initially the departure was somewhere beyond .125". Could've likely driven a greyhound bus through the clearance ( OK joking a bit).
Seriously ungood, probably most of the issue there. That's allowing the pedal/linkage/throwout bearing to over travel, which is why the fingers are hitting.
100% agree. Just sent several pic's to a tech at CF, his thoughts are this pressure plate was hosed from the get go or became so after install. he said in his opinion and experience two of the 3 lifting arms were not lifting or sitting down at the same as the third which correlates to the hot spots on the PP.
Parts just arrived so off to work I go wink May not know much until the linkage parts arrive from Brewer's which likely won't be until next week.
Will keep all updated
Re: New clutch, SEVERE Chatter from a stop NOW WITH PIC's [Re: cudaman1969] #3168920
08/18/23 09:21 PM
08/18/23 09:21 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Originally Posted by cudaman1969
Originally Posted by HotRodDave
1, Get a new pressure plate, clean it very well with blue shop towels and brake clean and do not touch it on the friction side afterwards, even normal skin oil is bad.
2. Get the flywheel re-ground by a different shop, they used too fine of a stone, that is not an 80 or 90 grit finish and it has weird patterns off to the right like someone hit it with a cookie disc or something. Also clean it with blue shop towels and brake clean and do not touch it afterwards.
3. get a new friction disc and do not touch it
4, make sure there is no excessive grease on the input shaft or throwout bearing (or anything in there for that matter as even a little tiny bit on the friction surface can cause issues)
Do not let it get any greasy hand prints on any of the friction surfaces of the disc, pressure plate or flywheel!
Doing all that will cure any issue inside the bellhousing.
All good points but I’ll add, do not grease the pilot busing, it’s silicon-bronze it lubricates itself and will not cut grooves like the roller bearing will.
Be weary of some bushing which aren't oil impregnated. I've seen them being sold at some shows.
Re: New clutch, SEVERE Chatter from a stop NOW WITH PIC's [Re: PhillyRag] #3168935
08/18/23 10:07 PM
08/18/23 10:07 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
iagree With our current supply chains executive money grubbing, cost cutting, and overseas suppliers trying to out bid each other it is hard to know who to trust anymore when it comes to quality. Quality sources/brands are not what they used to be. Even Napa has buckled in to selling πŸ’©. So one does have to be very selective when choosing parts. up twocents
Re: New clutch, SEVERE Chatter from a stop NOW WITH PIC's [Re: TJP] #3168965
08/19/23 06:59 AM
08/19/23 06:59 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Before removing the flywheel, I'd like to check the runout of the face. Indicator base on the block, needle on the face.
That dark spot looks about 180 from where the grinding marks are visible. Like the flywheel wobbles.
Be a good idea to check that on the new flywheel too. Who knows if the crank flange is bent. Unlikely but not impossible.
Bellhousing concentricty is important too.
There may be multiple little things adding up.
Angry white pureblood male
Re: New clutch, SEVERE Chatter from a stop. SOME UPDATES [Re: ruderunner] #3169554
08/21/23 10:24 PM
08/21/23 10:24 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
A kwik update:
1. The crank flange had a high spot ring around the outside preventing the FW from sitting flat on the entire flange surface. Wasn'nt really noticeable until one looked at flange pattern the back of the FW. Rust or something similar (orange & black spotting) was evident on the flange. A kwik pass with a flat aluminum block confirmed the presence of the ring.
2. The pilot bushing was not installed straight as the upper lip was proturding
3. The Z bar mount is definitely tweaked
4. new flywheel mounted showed 0 variation to the block measured across the face
5. Bellhousing run out checked at .022" eek
Waiting for offset dowels to get the bellhousing in spec wink beer
Re: New clutch, SEVERE Chatter from a stop. SOME UPDATES [Re: TJP] #3169699
08/22/23 02:23 PM
08/22/23 02:23 PM
moparx Offline
moparx  Offline
glad to see everything is getting back to normal. up
did you check runout on the old flywheel ? if you did, i missed it.
who knows "how many fingers has been in that pie" in over 50+ years ? laugh2
beer
Re: New clutch, SEVERE Chatter from a stop. SOME UPDATES [Re: moparx] #3169806
08/22/23 10:10 PM
08/22/23 10:10 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
beer
No I did not, When I saw the PP I figured anything beyond wass just burning time. I already have too much in it as it is frown beer
Re: New clutch, SEVERE Chatter from a stop. SOME UPDATES [Re: TJP] #3169880
08/23/23 11:46 AM
08/23/23 11:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A kwik update:
Hopefully the RobbMc dowels and directly from Him , Summit sells the lakewood branded RobbMc type now and they are almost 150 a pair vs. 39 a pair ...
Re: New clutch, SEVERE Chatter from a stop. SOME UPDATES [Re: TJP] #3169910
08/23/23 01:57 PM
08/23/23 01:57 PM
moparx Offline
moparx  Offline
well having too much to do, plus a little more, keeps one out of the bars and away from chasing wild women. panic laugh2
beer
Re: New clutch, SEVERE Chatter from a stop. SOME UPDATES [Re: moparx] #3170248
08/24/23 09:39 PM
08/24/23 09:39 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
beer
up up
Never been one for bars, my mother taught me it was god place to find trouble whether you wanted it or not wink This was further impressed upon my young mind when a good friends neighbor had an altercation with an individual at a small strip mall bar on a Saturday early afternoon in a nice part of Santa Clara, Ca about 1973-4. The disagreement was settled out back with the other person leaving afterwards. 2 or 3 hours later when the neighbor walked out the front door he was blasted twice with a 12ga. down
Wild women? known a few, kind of like bars IMO, nothing but trouble whistling LOL No use for them either whistling beer
Re: New clutch, SEVERE Chatter from a stop. SOME UPDATES [Re: JohnRR] #3170249
08/24/23 09:45 PM
08/24/23 09:45 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
A kwik update:
I certainly wish i had know about those before pulling the trigger on the summit / lakewood ones frown Oh well next time up
Didn't get much accomplished today other removing the dowels. The welding a bolt trick worked really well especially with the motor still in the car. So thanks for the suggestion up Still learning at 69 YO beer
Attaching a few pic's of the back of the crank and FW where one can see it was only seating on the outer edge along with non shouldered bolts eek
Re: New clutch, SEVERE Chatter from a stop. SOME UPDATES [Re: TJP] #3170312
08/25/23 10:06 AM
08/25/23 10:06 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Nothing like multiple issues contributing to one big problem. Back in the 80's, I had a 360 crank worked on by Hank The Crank. One of the operations done by them was to true up the rear flange.
Carl Kessel
Re: New clutch, SEVERE Chatter from a stop. SOME UPDATES [Re: CKessel] #3170327
08/25/23 11:12 AM
08/25/23 11:12 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I was thinking maybe a bent crank
Re: New clutch, SEVERE Chatter from a stop. SOME UPDATES [Re: TJP] #3170333
08/25/23 11:30 AM
08/25/23 11:30 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A kwik update:
I thought everyone that's a longtime member knew about them , the good thing I guess is it's on the customers dime. I have all 3 available offsets in my stash , would have really hurt at the summit price ...
The first time I bought them all they were only 28 a set ...
RobbMC dowels
Re: New clutch, SEVERE Chatter from a stop. SOME UPDATES [Re: JohnRR] #3170346
08/25/23 11:56 AM
08/25/23 11:56 AM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
RobbMC dowels
I have his site bookmarked now. And I agree, the Lakewood prices are flat thievery IMO twocents beer
Re: New clutch, SEVERE Chatter from a stop. SOME UPDATES [Re: TJP] #3170553
08/26/23 11:04 AM
08/26/23 11:04 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Summit branded offset dowels are even less than RobbMc
https://www.summitracing.com/search/part-type/bellhousing-dowel-pins?N=dowel-pin-diameter-in%3A0-500-in
Re: New clutch, SEVERE Chatter from a stop. SOME UPDATES [Re: Sniper] #3170582
08/26/23 01:00 PM
08/26/23 01:00 PM
moparx Offline
moparx  Offline
the only drawback with those dowel pins, they are .500, while the mopar pins are .495-.496.
that extra .004 in diameter will prove to be fun installing them, then the bellhousing or transmission case holes may need enlarging by a few thousandths so the pins fit there.
beer
Re: New clutch, SEVERE Chatter from a stop. SOME UPDATES [Re: Sniper] #3170598
08/26/23 01:54 PM
08/26/23 01:54 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
Just an FYI Sniper, please feel free to correct me if I am wrong wink
the summit pins are oversized at .500 which work well in a ford but Mopar's use a .496 diameter pin. If one does get them in you're not going to turn them. Additionally, the same is true for the bell housing side/holes as I found out yesterday spank spank
So to use the "Other guys" pins one will have to polish them down with some aggressive paper (80 grit) and a lathe, drill press or such. DO REMEBER you have to do BOTH ends of the Dowel. If not when installing the bellhousing it may push the offset side of the dowel partially into the block causing it to seize as I found out yesterday, My D/A fault for not thinking this through spank again. Fortunately this only happened on 1 of the 2 pins and it was the lower more accessible one.
After seizing, it broke one allen driver bit while trying to rock it back and forth. OK get another. The sides of the allen socket on the dowel then split/ fractured. THANK GOD FOR CARBIBDE BITS πŸ™
So what should have been a 2-3 hour job at most turned into about 8-9. down
The RobMc pins are a two piece design in which the dowel in the block is separate from the bellhousing dowel. Once installed you rotate the bellhousing half of the pin to where you want it and the lock it down with the internal screw. Last night I would have paid 300.00 for a pair of those pins. ROBMC PIN LINKY
I tried ordering them yesterday but no one answered frown
From my limited searching he and Brewers appear to be the only offering the correct size pins. It was too late for Brewers.
And I alos thought about John RR as he said he had them but again to late to get them o/nited
So Today I will give the summit ones another shot with both ends turned down to the .496 diameter. Wish me luck wink beer
Re: New clutch, SEVERE Chatter from a stop. SOME UPDATES [Re: moparx] #3170602
08/26/23 01:57 PM
08/26/23 01:57 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
beer
OK You Treed me are we even now ? πŸ˜‚πŸ˜‚ beer
Re: New clutch, SEVERE Chatter from a stop. SOME UPDATES [Re: TJP] #3170614
08/26/23 03:05 PM
08/26/23 03:05 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Well, the Mopar pins are at .500" too so your screwed which ever way you go.
