Re: Aftermarket Hemi Pistons part number
[Re: 68jim]
#3169454
08/21/23 03:29 PM
08/21/23 03:29 PM
Posts: 17,842 S.E. Michigan
ZIPPY
S.E. Michigan
From the underside, probably looking at a raw forging/raw casting number that is then machined into several different finished parts, given different part numbers, and then put into a package of 8 with wrist pins and so on and assigned different part numbers again.
I'm sorry that's not helpful at all but it may just be an internal ID number for the piston mfg, and no good to you and me.
Rich H.
Esse Quam Videri
[Re: 68jim]
#3169548
08/21/23 09:09 PM
08/21/23 09:09 PM
Posts: 2,639 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I did not build this engine and assumed they were Keith Black Hypereutectic pistons. 68jim I would never assume that. I don't even know if those existed back then. My guess is that is an old TRW forging number. And could very well be 12.5 since that was a common race cr. If you take the spark plugs out and look inside 12.5's come way up there.
2011 Drag Pak Challenger
[Re: rickseeman]
#3169616
08/22/23 09:41 AM
08/22/23 09:41 AM
Posts: 21,416 It's a dry heat
gtx6970
It's a dry heat
I did not build this engine and assumed they were Keith Black Hypereutectic pistons. 68jim I would never assume that. I don't even know if those existed back then. My guess is that is an old TRW forging number. And could very well be 12.5 since that was a common race cr. If you take the spark plugs out and look inside 12.5's come way up there. Agreed, a 12.5 piston ( shown ) will have a sharp dome on it compared to say a 10.5 piston
[Re: moparx]
#3169708
08/22/23 02:39 PM
08/22/23 02:39 PM
gtx6970
It's a dry heat
however, [and i know virtually nothing about a hemi] without knowing the head combustion chamber volume, would those pistons really be 12.5 : 1, say, on a stock head that never had work done to it ? please educate me some on gen 2 hemi's. Same as other engine. Final compression depends on cyl head cc. Head Gasket thickness. Etc etc
[Re: 68jim]
#3169727
08/22/23 03:29 PM
08/22/23 03:29 PM
Posts: 1,321 VA
dragon slayer
VA
[Re: 68jim]
#3169729
08/22/23 03:31 PM
08/22/23 03:31 PM
rickseeman
Stuttgart, Arkansas
If it's a 12.5 you won't need a borescope. It will be very close. They made a 12.5 Hi-top that nearly hits the plug.
[Re: gtx6970]
#3169737
08/22/23 03:44 PM
08/22/23 03:44 PM
Posts: 19,383 north of coder
moparx
however, [and i know virtually nothing about a hemi] without knowing the head combustion chamber volume, would those pistons really be 12.5 : 1, say, on a stock head that never had work done to it ? please educate me some on gen 2 hemi's. Same as other engine. Final compression depends on cyl head cc. Head Gasket thickness. Etc etc as i surmised, however, as has been, already stated, [i now know ?] the pistons come closer to the plug than the valves ? [depending on cam lift and duration specs ?]
