Re: TDC Question
[Re: 6PAX]
#3168555
08/17/23 02:43 PM
08/17/23 02:43 PM
Posts: 16,931 NC
440Jim
NC
Looking at the top two pictures, would you say cylinder #1 or #6 is on TDC? With the balancer set on TDC, the top pic are the lifters for #1 and the bottom for #6. Top two pics, #1 is firing and #6 is on overlap. It should be even more obvious 20-30 degrees after TDC on the balancer/timing marks; the cylinder on overlap will have the intake opening.
Re: TDC Question
[Re: 6PAX]
#3168561
08/17/23 03:00 PM
08/17/23 03:00 PM
Posts: 4,211 New York
polyspheric
New York
Both are @ TDC: one is firing and the other is on OL. Every 360 degrees they switch
Boffin Emeritus
Re: TDC Question
[Re: 440Jim]
#3168809
08/18/23 01:44 PM
08/18/23 01:44 PM
Posts: 16,931 NC
440Jim
NC
It should be even more obvious 20-30 degrees after TDC on the balancer/timing marks; the cylinder on overlap will have the intake opening. This Comp Cams diagram might help you visualize what I said.
Re: TDC Question
[Re: B1MAXX]
#3169099
08/19/23 09:14 PM
08/19/23 09:14 PM
Posts: 31,075 Oregon
AndyF
Agreed I just take it one more step, after pointing the rotor at the right tower I fine tune the reluctor to line up. Yah, having a reluctor makes it a little more difficult. Back in the old days when I ran electronic ignition I would machine additional slots in the reluctor so I could fine tune the rotor phasing. That was actually a requirement for some performance engines with vacuum advance. The factory reluctor position wouldn't work on some combinations. I had forgotten about that since I haven't used a reluctor based ignition system in 20 years.
Re: TDC Question
[Re: B1MAXX]
#3169159
08/20/23 10:17 AM
08/20/23 10:17 AM
RapidRobert
not a dealbreaker but I would run the plug wires in the OE order around the cap which lets em lay the neatest with the shortest lengths possible. this might help prevent a future mistake. EDIT this would be the #1 plug wire in the cap facing the front of the engine on a SB and at the 5 o'clock position looking over the pass fender on a BB. you can reclock the intergear to get it where you want it. be sure to check rotor phasing & with no vac adv I want it dead centered and with vacuum advance I want the trailing edge of the rotor tip at the trailing edge of the cap terminal as vac adv will pull it back against rotation as only vac adv not mechanical advance changes phasing. You can redrill the reluctor with a mini drill bit then break the edge out with a mini file to reclock the roll pin in the reluctor to change phasing and Echlin has a rotor with a longer blade (MO3000 iirc) that will help reduce the gap.
Re: TDC Question
[Re: B1MAXX]
#3169195
08/20/23 01:07 PM
08/20/23 01:07 PM
Posts: 2,080 CA
crackedback
CA
Where the slot in that drive goes is dependent on the distributor. MSD's have been known in some engines to be miles off with rotor direction/#1 tower when the drive is installed per the manual.
I usually identify where I want the #1 tower on distributor, figure out where the tang is pointing, get drive dropped in. Then when ready to fire it up and wired, hook up a timing light on #1 wire, timing mark in 15-20 BTDC area. On a BB turn housing counter clockwise, turn on ign, and twist housing slowly back clockwise watching for the flash. Should be very close to timed up.
