Weld Through Primer #3168192
08/15/23 10:24 PM
08/15/23 10:24 PM
Pennsylvania
proshiftcharger Offline OP
Pennsylvania
Who makes a good weld through primer that you can buy online?
Thanks !
Re: Weld Through Primer [Re: proshiftcharger] #3168195
08/15/23 10:32 PM
08/15/23 10:32 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Eastwood Automotive makes some and so does Por-15. Check out Eastwood
Seems to be only available in aerosol cans in both the Eastwood and Por-15 ? shruggy https://www.eastwood.com/search/?q=weld%20thru%20primer
Re: Weld Through Primer [Re: A12] #3168200
08/15/23 10:45 PM
08/15/23 10:45 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
I have used the Eastwood primer and it works well. and yes it only come in aerosol cans.
My Monster are real!
Living within your means makes life pretty easy.
Re: Weld Through Primer [Re: 67vertman] #3168235
08/16/23 09:19 AM
08/16/23 09:19 AM
mopar4don Offline
mopar4don  Offline
Re: Weld Through Primer [Re: proshiftcharger] #3168763
08/18/23 10:52 AM
08/18/23 10:52 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I've used SEM I picked up at NAPA with good results
Re: Weld Through Primer [Re: JohnRR] #3168992
08/19/23 10:21 AM
08/19/23 10:21 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
