1955 Dodge Body Swap #2840053
11/01/20 10:26 AM
11/01/20 10:26 AM
Great Falls, MT
HWC Offline OP
HWC  Offline OP
Great Falls, MT
Does anyone have knowledge about swapping the body of a 1955 Dodge Pickup onto a Dodge Dakota or Dodge 1500 chassis?
Any help would be appreciated.
Thanks,
Wayne
Re: 1955 Dodge Body Swap [Re: HWC] #2840056
11/01/20 10:36 AM
11/01/20 10:36 AM
Between Houston & Galveston TX
SattyNoCar Online work
SattyNoCar  Online Work
Have you looked thru the STREET RODDERS section here at Moparts? May not find an exact year match, but Dakota swaps have been discussed enough that you may get some ideas.
Welcome to the site!
beer
John
Re: 1955 Dodge Body Swap [Re: SattyNoCar] #2840152
11/01/20 01:25 PM
11/01/20 01:25 PM
moparx Offline
moparx  Offline
member "poorboy" is THE expert on dakota chassis swaps.
also, welcome to the board as well ! wave
beer
Re: 1955 Dodge Body Swap [Re: SattyNoCar] #2840182
11/01/20 02:02 PM
11/01/20 02:02 PM
Great Falls, MT
HWC Offline OP
HWC  Offline OP
Great Falls, MT
Thank you, I will do that.
Re: 1955 Dodge Body Swap [Re: HWC] #2840352
11/01/20 07:19 PM
11/01/20 07:19 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
D1500 is to wide for a 55 pu. You need a Dakota. Check this out https://board.moparts.org/ubbthread...n-a-2005-dakota-chassis.html#Post1313950
Re: 1955 Dodge Body Swap [Re: Dabee] #2840561
11/02/20 09:57 AM
11/02/20 09:57 AM
Great Falls, MT
HWC Offline OP
HWC  Offline OP
Great Falls, MT
Thank you for the link, it was helpful and appreciated
Re: 1955 Dodge Body Swap [Re: HWC] #2840621
11/02/20 11:45 AM
11/02/20 11:45 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I looked into this when I had my old 51. It is a lot of work. You can also cut the entire front clip off a Dakota and use that. Fatman's had a frontend kit also. I think it runs around 4k complete. Then I thought about running a Gen I Hemi, but ended up getting the old I6 running/driving before I sold it. If you use the entire Dakota you will have to modify the fire wall and floor. Check here for more info. https://p15-d24.com/
Coming soon!!!!
Re: 1992 390 Magnum to Carburation [Re: Mr.Yuck] #2842452
11/06/20 09:14 AM
11/06/20 09:14 AM
Great Falls, MT
HWC Offline OP
HWC  Offline OP
Great Falls, MT
I am building a 1955 Dodge 1/2 pickup on a 1992 Dakota with a 390 Magnum and automatic transmission. How difficult is it to keep the TBI and original ECM or should I Can switch to a carburetor? If I switch and eliminate the ECM how do I get the transmission to shift?
Anyone have a suggestion?
Re: 1992 390 Magnum to Carburation [Re: HWC] #3168160
08/15/23 08:07 PM
08/15/23 08:07 PM
Great Falls, MT
HWC Offline OP
HWC  Offline OP
Great Falls, MT
Re: 1992 390 Magnum to Carburation [Re: HWC] #3168169
08/15/23 08:41 PM
08/15/23 08:41 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
If you use the transmission out of the 92 Dakota, and it is an OD transmission, it is hydraulicly shifted instead of electronically controlled. You can rig up pressure switches and relays to make the trans work normally. As far as controlling the engine, you may need to switch the ECM and wiring over to OBD2 style, which is 96 and up. To make the computer work well with a 390 CI motor, you will need to get Flyin Ryan Performance to tune the ECM for you.
Re: 1992 390 Magnum to Carburation [Re: JDMopar] #3168181
08/15/23 09:22 PM
08/15/23 09:22 PM
Great Falls, MT
HWC Offline OP
HWC  Offline OP
Great Falls, MT
Thank you very much for your insights. Do you think it is reasonable to save the complete wiring harness or would it be just easier to change to carburation?
I really appreciate your help!
Thank you
Wayne
Re: 1992 390 Magnum to Carburation [Re: HWC] #3168184
08/15/23 09:31 PM
08/15/23 09:31 PM
Thank you
Wayne
That is your call on the carb or EFI work
Which one do you like or dislike working on the most work grinshruggy
I would choose the more challenging one, but that is me, not you wave shruggy
Re: 1992 390 Magnum to Carburation [Re: Cab_Burge] #3168191
08/15/23 10:23 PM
08/15/23 10:23 PM
Great Falls, MT
HWC Offline OP
HWC  Offline OP
Great Falls, MT
That is an interesting statement and one I agree with, but my experience has been restoring stock classic cars; Model T’s and old Chevys. I have never built a “resto-rod” or custom like this before. I am fine with the fabrication, body work and painting, but I am new to this custom engine stuff.
Are you familiar with an article I could read about switching from TBI to carburation. I have search the internet, but can not find what I need.
Re: 1955 Dodge Body Swap [Re: HWC] #3168201
08/15/23 10:55 PM
08/15/23 10:55 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
This is a current thread in the Truck section: https://board.moparts.org/ubbthreads/ubbthreads.php/topics/3166022/1/no-frame-cutting-swap.html
If that doesn't answer your questions, feel free to start you own thread. There's plenty of good knowledge/experience around here...
Re: 1955 Dodge Body Swap [Re: Fat_Mike] #3168230
08/16/23 08:34 AM
08/16/23 08:34 AM
Great Falls, MT
HWC Offline OP
HWC  Offline OP
Great Falls, MT
Mike, I am thankful for your input. I started that thread a couple years ago.
I tried to start a new thread, but for some reason could not figure out how to do it. I send an email to the administrator but that person never replied. If you could tell me how to start a new thread, I would gladly do so as I do know that would be the correct way to get the information I need. If you could tell me how, I would be very appreciative.
Thank you,
Wayne
Re: 1955 Dodge Body Swap [Re: HWC] #3168256
08/16/23 11:48 AM
08/16/23 11:48 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Sure.
Log in, go to the truck section (Sandy's Truck Stop), somewhere near the top left you'll see a box that says "New Thread." Click on that and type away...
Re: 1955 Dodge Body Swap [Re: HWC] #3168382
08/16/23 08:54 PM
08/16/23 08:54 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Wayne, Fat Mike's walk through will get you onto the Street Rod section. There are a ton of old Dodge truck sheet metal on Dakota chassis threads there. Lots of people with lots of experience that would reply pretty quickly.
A build process is pretty difficult to do on Moparts with only being ably to post 4 pictures at a time, and this section isn't really where the kind of build you are looking for should be. I have a picture heavy build thread on a 49 Dodge on a Dakota 4x4 chassis in the street rod section. Its not an easy project, but it sure is worth the effort to me.
Just as a highlight, a before, a couple during, and an after pic for you.
