Re: Did I kill my Optima? [Re: RTSE4ME] #3167696
08/13/23 06:33 PM
08/13/23 06:33 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Re: Did I kill my Optima? [Re: A12] #3167698
08/13/23 06:45 PM
08/13/23 06:45 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Get an AGM battery charger with "Desulfation Mode" like the CTEK or similar units. The desulfation mode is very, very useful and works.....most of the time.
Re: Did I kill my Optima? [Re: A12] #3167760
08/14/23 06:32 AM
08/14/23 06:32 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
I have a BatteryMINDER Plus. Someone on here recommended it a few years ago. I brought back a dead battery for a car on it. It has a desulfator mode. I did have to charge it with a larger battery charger to get it to a certain voltage for it to work.
Re: Did I kill my Optima? [Re: A12] #3167851
08/14/23 01:46 PM
08/14/23 01:46 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I found the video interesting.
I wish he had used a Hall Effect DC current meter to show what the battery to battery DC current was in his dual battery set up.
It is also interesting to hear an Optima “pro” say publicly that de-sulfation pulsing works.
Re: Did I kill my Optima? [Re: 360view] #3167870
08/14/23 02:45 PM
08/14/23 02:45 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Re: Did I kill my Optima? [Re: Vert] #3169144
08/20/23 08:25 AM
08/20/23 08:25 AM
Berlin NJ
scottk Offline
scottk  Offline
Berlin NJ
Originally Posted by Vert
Grab a NOCO GENIUS10 charger.
https://no.co/genius10
They are approx $100. Home Depot sells them, Battery Warehouse, Amazon... Get best reviews and ratings. I love mine. Have the 10 and the 5.
GENIUS10 6V/12V 10-Amp Smart Battery Charger
10-Amp Battery Charger, Battery Maintainer, and Battery Desulfator
Introducing the all-new GENIUS10, one of our most powerful, highest-performing, energy-efficient, and compact chargers yet. The GENIUS10 is a 6-volt and 12-volt battery charger, battery maintainer, and battery desulfator rated at 10-amp for lead-acid automotive, marine, and deep-cycle batteries, including flooded, gel, AGM, and maintenance-free, plus lithium-ion batteries.
Meet the GENIUS10 - Similar to our G7200, just better. It's 17% smaller and delivers 115% more power. And it's simpler and easier to use than ever before.
Do more with Genius - Designed for 6-volt and 12-volt lead-acid automotive, marine, and deep-cycle batteries, including flooded, gel, AGM, and maintenance-free, plus lithium-ion batteries.
Enjoy precision charging - An integrated thermal sensor detects the ambient temperature and alters the charge to eliminate over-charging in hot climates and under-charging in cold climates.
Charge dead batteries - Charges dead batteries as low as 1-volt. Or use the all-new Force Mode that allows you to take control and manually begin charging dead batteries down to zero volts.
Simple to set up and use - Plug-in, connect to the battery, select a charge mode, and start charging your battery. A fully-automatic, worry-free battery charger for year-round use.
Restore your battery - Detects sulfation and acid stratification and restores lost performance for stronger engine starts and extended battery life.
Compatible with all types of vehicles - Charge and maintain cars, motorcycles, lawnmowers, ATVs, tractors, trucks, SUVs, boats, classic cars, hot rods, and more - you name it.
Thank you so much for this tip. I have 3 group 31 AGM batteries in my boat. Over the winter one held the charge pretty well. The other 2 were down to around 6 volts. Bought a Harbor Freight charger with the AGM setting. Told me after a brief time that both batteries were no good. Tried to force a charge with my 40 year old Craftsman charger for an half hour and no voltage increase. Was reading this on here the other night and decided to give it a try. Well, after an 8 hour charge, got the green light and 12.7 volts in the battery. One of the batteries was a year old and the other 2 years old. Again, thanks for the huge tip. up
Re: Did I kill my Optima? [Re: Vert] #3171394
08/29/23 03:36 PM
08/29/23 03:36 PM
MD
RTSE4ME Online content OP
RTSE4ME  Online Content OP
MD
So I end up buying a NOCO GENIUS10 AND A GENIUS1 AND NOW I feel like an idiot.
Tried bringing the sub-Optima battery back to life. Put charger in repair mode overnight and it went into standby mode.
Then put it in AGM charge mode and get a message stating you have a completely over priced utter piece of garbage OPTIMA battery.
So this won't be a total loss, I am going to use this POS Yellow Top for 1000 yd. target practice. I have a nice new custom rifle in 6.5 Creedmoor that I have never shot.
Re: Did I kill my Optima? [Re: RTSE4ME] #3171454
08/29/23 06:38 PM
08/29/23 06:38 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
laugh2
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Did I kill my Optima? [Re: RTSE4ME] #3171465
08/29/23 07:18 PM
08/29/23 07:18 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Did you watch the Optima video I linked?
Re: Did I kill my Optima? [Re: A12] #3171516
08/29/23 10:49 PM
08/29/23 10:49 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Originally Posted by A12
Originally Posted by Sniper
Originally Posted by Bad340fish
Most chargers won't kick on if the battery is below 10 volts
There is a reason for that, it's called thermal runaway. A possibility when trying to charge a deeply discharged battery not designed for deep discharge. Now before someone pipes up with how they've done it for years with no problems, yeah I know I've done it too, but you aren't going to get sued if it happens and someone's house and car burns down. So the charger manufacturers but in limitations to mitigate that risk. What you do to defeat that is up to you.
Yeah just asked Jim about that. Sorry Jim to bring up bad memories. frown
That was a power tool battery not a car battery
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Did I kill my Optima? [Re: 340SIX] #3171519
08/29/23 11:00 PM
08/29/23 11:00 PM
340SIX Offline
340SIX  Offline
I have a battery charger just like the one in the video, and gave dine judt like he did in it just did one last week for someone.
I do like my 3 maintainers i have. I have 2 small ones a a slightly larger one. They say they are also diffuser 2 are 3 years old other is 2.
Re: Did I kill my Optima? [Re: RTSE4ME] #3171568
08/30/23 09:10 AM
08/30/23 09:10 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Originally Posted by RTSE4ME
I am debating on buying a Optima charger. Took the battery in this week to parts store and left it overnight.
Still dead 11.7 volts. I have had 4 Optima's 2 Red & 2 Yellows now down to 1 Yellow. I just hate giving them more $$$ for their crap. I hear Odyssey make a good AGM but pricey.
Funny my tractors have had the best Batteries. John Deer garden tractor finally replaced OEM battery after 22 years. My 38 hp Kubota still has original battery 17 years old.
None of my car batteries last much more than 5
Some years ago I read an interview of a Johnson Controls engineer. He said that all of the different brands of batteries they make have exactly the same components but the better ones have more of the same plates as the the cheaper batteries. He said the heavier it is the more plates are in it so buy the heaviest one you can find. When he was asked which one that would be he said John Deere.
Re: Did I kill my Optima? [Re: A12] #3171602
08/30/23 11:49 AM
08/30/23 11:49 AM
MD
MD
Yes, I already did what was in the video. They did leave out one important step......Get tannerite and blow
the over-priced POS up and never ever buy an Optima battery.
Re: Did I kill my Optima? [Re: RTSE4ME] #3171688
08/30/23 03:54 PM
08/30/23 03:54 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
The only experience I have with Optima batteries is with our boat (5.7L Mercruiser) where I have two Blue top marine deep cycle batteries and so far good service. Agree with the "over-priced", that's over $600 of over-priced deep cycle batteries sitting hidden in a corner of an old boat. You have to wonder why with all of the decades and decades of poor performance and expense with batteries in general would anyone want to buy an EV shruggy wink laugh2
Re: Did I kill my Optima? [Re: A12] #3172254
09/02/23 09:41 AM
09/02/23 09:41 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
All I can add is that I have had great luck with Optima batteries past and present.
Re: Did I kill my Optima? [Re: 340Cuda] #3172474
09/02/23 11:12 PM
09/02/23 11:12 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I second the NOCO genius charger I use one to keep my marine batteries over the winter.. The dual charger is super convenient and as stated they just plain work...
Re: Did I kill my Optima? [Re: screamindriver] #3172504
09/03/23 08:49 AM
09/03/23 08:49 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I have a blue top in my boat, it does the job. But I can charge it, and no mater what the next morning after sitting it will only have 11.9 volts. Starts the boat, fishes all day, but never has more than 11'9 volts after a charge (and sitting a bit). This always gives me the heebie-jeebies
