Tire size ,cop wheels on a 67 B-body #316746
05/13/09 07:52 AM
05/13/09 07:52 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I have a 67 Coronet drum brakes all the way around,SS Springs on the rear, I'm thinking about putting on 7" steel cop wheels all the way around they have 4.375 BS. My question is what size tires should go on this setup and look good and not give me any problems with clearence. I would kinda like to keep all 4 the same size so I can rotate them.
Re: Tire size ,cop wheels on a 67 B-body [Re: flatiron] #316747
05/13/09 04:07 PM
05/13/09 04:07 PM
Pittsburgh, Pa
Jeff_383 Online content
Jeff_383  Online Content
Pittsburgh, Pa
I would say if you're going to have all four the same, 235/60's would look good. If not, I have a 275/60 on a 7" steel wheel, with 4.25" BS. No rub
Re: Tire size ,cop wheels on a 67 B-body [Re: Jeff_383] #316748
05/13/09 07:54 PM
05/13/09 07:54 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
225/70/15 would look good all the way around
Re: Tire size ,cop wheels on a 67 B-body [Re: rrunner] #316749
05/13/09 08:07 PM
05/13/09 08:07 PM
Dexter, Michigan
copper67440 Offline
mopar addict
copper67440  Offline
mopar addict
Dexter, Michigan
More info here Dodge coronet Registry
Re: Tire size ,cop wheels on a 67 B-body [Re: rrunner] #316750
05/13/09 08:33 PM
05/13/09 08:33 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
You're looking at them.
Re: Tire size ,cop wheels on a 67 B-body [Re: Michael] #316751
05/14/09 08:28 AM
05/14/09 08:28 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
you might be able to squeeze 255/60's on there, too....
2017 Grand Cherokee Overland
Re: Tire size ,cop wheels on a 67 B-body [Re: flatiron] #316752
05/14/09 09:19 AM
05/14/09 09:19 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I used a 275/60/15 on a 67 GTX and Coronet. The rub up in the well on big bumps...and these cars had XHD springs. The SS's should give you a little more ride hight. These are L60/15 slicks fronts are 215/75/15's on a 15x6 rim
Coming soon!!!!
Re: Tire size ,cop wheels on a 67 B-body [Re: rrunner] #316753
05/14/09 09:39 AM
05/14/09 09:39 AM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: Tire size ,cop wheels on a 67 B-body [Re: deansrr] #316754
05/14/09 09:54 AM
05/14/09 09:54 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
too skinny and short for the rear...
Coming soon!!!!
Re: Tire size ,cop wheels on a 67 B-body [Re: Mr.Yuck] #316755
05/14/09 12:53 PM
05/14/09 12:53 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I run 245/60's on 7" steelies in back on mine. Look pretty good, and not even close to rubbing with stock springs. If an aggressive look is what you're going for, I'd go with a 255/60 on the 7" rims out back. Then balance that with a 215/70 on a 6" rim in front (very close in Ht., but the extra width in both the tire and rim out back will provide a nice stance).
Re: Tire size ,cop wheels on a 67 B-body [Re: Mr.Yuck] #316756
05/14/09 01:35 PM
05/14/09 01:35 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
if you want more of a stock look and to be able to rotate your tires as said before, then 225/70r15 would be a better setup, close to OE size
Re: Tire size ,cop wheels on a 67 B-body [Re: deansrr] #316757
05/14/09 02:47 PM
05/14/09 02:47 PM
Puyallup, WA
Puyallup, WA
although he hasn't shown us the car, or let us know what look he's going for, the fact that the car has SS springs would lead me to believe he's not going for an OEM look (???)
Re: Tire size ,cop wheels on a 67 B-body [Re: StealthWedge67] #316758
05/14/09 02:54 PM
05/14/09 02:54 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
that and the fact that he'd use cop wheels...
Re: Tire size ,cop wheels on a 67 B-body [Re: Mr.Yuck] #316759
05/14/09 03:15 PM
05/14/09 03:15 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
You are correct OEM dosen't mean squat to me. I'm just in a situation were I need to set of tires and can only afford one.
Re: Tire size ,cop wheels on a 67 B-body [Re: flatiron] #316760
05/14/09 04:04 PM
05/14/09 04:04 PM
Virginia
JimG Offline
JimG  Offline
Virginia
Attached is a pic of my car (I brightened it so you could see the tires) with 225-70-15's all around.
I think that size tire looks too big on thye front and have since switched to 60's. In the rear, I like the taller 70 series tire.
These tires are very close to the wheelwells. I can't slip my hand very far into the wheelwell due to the close proximity of the tire to the wheelwell.
Re: Tire size ,cop wheels on a 67 B-body [Re: JimG] #316761
05/14/09 04:11 PM
05/14/09 04:11 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I like the looks of those. But I do agree the fronts do look a tad big.
Re: Tire size ,cop wheels on a 67 B-body [Re: flatiron] #316762
05/14/09 07:00 PM
05/14/09 07:00 PM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
Here is a possibility....fronts: 215/70/15 Rears: 255/70/15. That should fit. The biggest problem is in the hiney. Cop wheels are normally 4 1/4 back spacing. I have 4.5 back spacing and 275/60/15 in the rear. It's tight but no rubs. The above combo should work. Pay attention the section width of the rear tires. You should go no more than 10.5 inches with cop wheel back spacing.
Re: Tire size ,cop wheels on a 67 B-body [Re: BELVEDERE67] #316763
05/14/09 09:48 PM
05/14/09 09:48 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Yea, nice combo, but he said he wants the same size so he can rotate them.
Re: Tire size ,cop wheels on a 67 B-body [Re: flatiron] #316764
05/14/09 09:52 PM
05/14/09 09:52 PM
Midwest
RSNAKE Offline
RSNAKE  Offline
Midwest
Fastlane Classic Cars has a picture of a '67 GTX that I think has a perfect stance. It is using 255/60/15 all the way around.
[image]http://www.fastlanecars.com/Public/GetImageBuffer.aspx?VEHICLE_INVENTORY_ID=da965059-7813-4955-b69d-7009e5c6db9e&IMAGE_TYPE=fullSize&IMAGE_ID=76a61f9d-1bc6-4896-8ad0-102af5ed0273[/image]
I have no affiliation with that dealer. I just really like the look of that car and thought that you would find the info helpful.
Re: Tire size ,cop wheels on a 67 B-body [Re: RSNAKE] #316765
05/14/09 09:55 PM
05/14/09 09:55 PM
Midwest
RSNAKE Offline
RSNAKE  Offline
Midwest
Another pic of the same car. [image]http://www.fastlanecars.com/Public/GetImageBuffer.aspx?VEHICLE_INVENTORY_ID=da965059-7813-4955-b69d-7009e5c6db9e&IMAGE_TYPE=fullSize&IMAGE_ID=76a61f9d-1bc6-4896-8ad0-102af5ed0273[/image]
Fastlane Classic Cars '67 GTX
