2008 3.5L Chrysler Sebring Engine Code Issue #3167540
08/12/23 09:19 PM
08/12/23 09:19 PM
Berlin, CT
SportFuryS/23383 Offline OP
Confused
Confused
Berlin, CT
Hi Everybody,
It's been quite awhile since I posted here last and I'm sorry, but I'm trying to help out my stepdad. He recently bought a 2008 Chrysler Sebring with a 3.5 liter with only 118,000 miles on it, however it has a problem with throwing an engine code for a cam position sensor. It starts up with the code off but when we start driving it, the code comes back on. A new sensor was in it when we got it, then we put another new one in it and its still on. Any ideas of what it could be? Any help is appreciated, thanks in advance up
If You Ask Me This Whole World Has Gone To Hell- Creed Fisher
Proud Supporter Of LGBT (Liberty Guns Beer & Trump)
Re: 2008 3.5L Chrysler Sebring Engine Code Issue [Re: SportFuryS/23383] #3167542
08/12/23 09:42 PM
08/12/23 09:42 PM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
That 3.5 uses a timing belt, do you know the last time the belt was replaced? If there is a lot of slack in the belt it can throw off the cam/crank timing. It also could be 1or2 teeth off! I would also check/reset the cam/crank sync. using a scan tool.
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: 2008 3.5L Chrysler Sebring Engine Code Issue [Re: Wicked49670dart] #3167559
08/13/23 12:28 AM
08/13/23 12:28 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
2 different replacement cam position sensors in my '96 Breeze, both did the same thing; didn't affect the way the car ran, but would throw a code from time to time.
1st replacement went in a while after a timing belt replacement, when original one threw a code.
1st sensor was NAPA, 2nd was MoPar.
Cam sensor code apparently can actually be a bad signal from crank sensor, or a bad connection/junction.
If it gets bad enough, there's an Auto Shutoff in the PCM (at least in the Breeze) that should kill the engine before things get fatal.
Re: 2008 3.5L Chrysler Sebring Engine Code Issue [Re: Wicked49670dart] #3169414
08/21/23 12:43 PM
08/21/23 12:43 PM
Berlin, CT
Confused
Confused
Berlin, CT
I don’t think ever, but we took it off and we got that and other parts on the way
Re: 2008 3.5L Chrysler Sebring Engine Code Issue [Re: SportFuryS/23383] #3169537
08/21/23 08:35 PM
08/21/23 08:35 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I've had a couple of those 3.5s. Great little engines but yep...they need a belt at 100k. I lost one belt at 102k...lol. Look close at the water pump and the tensioner while you're in there. Get it up and running...if it still sets a code please tell us which exact code.....saying it "throws a code for the cam sensor" isn't helpful as there are likely multiple codes dealing with cam sensor(s).
Re: 2008 3.5L Chrysler Sebring Engine Code Issue [Re: Dcuda69] #3169695
08/22/23 02:12 PM
08/22/23 02:12 PM
moparx Offline
moparx  Offline
i did the belt, water pump, and tensioners in my wife's concorde with a 3.5 at 104k [and change]
i was surprised to find the original belt "looked" fine, but one of the tensioners [the only one ? i really forget] was starting to get a roughness in the bearing.
i think i got it just in time.
and for whatever it's worth, this car was a long trip, maintenance done as required, not beat on, vehicle.
beer
Re: 2008 3.5L Chrysler Sebring Engine Code Issue [Re: moparx] #3171242
08/28/23 11:42 PM
08/28/23 11:42 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Like Topside said "Cam sensor code apparently can actually be a bad signal from crank sensor, or a bad connection/junction. STAR would recommend that with cam sensor back in the day.
Re: 2008 3.5L Chrysler Sebring Engine Code Issue [Re: SALEM1912] #3171442
08/29/23 06:18 PM
08/29/23 06:18 PM
Berlin, CT
Confused
Confused
Berlin, CT
Well,
The timing belt, tensioner, pulley and water pump were replaced BUT unfortunately the light is still on. It does have a code called “cam position sensor intermittent” if that helps any. However we’re thinking it maybe an electrical issue……. Any ideas?
Re: 2008 3.5L Chrysler Sebring Engine Code Issue [Re: SportFuryS/23383] #3171478
08/29/23 08:28 PM
08/29/23 08:28 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Well,
What are the P codes?
Re: 2008 3.5L Chrysler Sebring Engine Code Issue [Re: NITROUSN] #3172120
09/01/23 04:18 PM
09/01/23 04:18 PM
Berlin, CT
Confused
Confused
Berlin, CT
This is the code it throws in my picture here. My stepdad replaced the crank sensor today and the light still comes on too
Re: 2008 3.5L Chrysler Sebring Engine Code Issue [Re: SportFuryS/23383] #3172122
09/01/23 04:26 PM
09/01/23 04:26 PM
Berlin, CT
Confused
Confused
Berlin, CT
Crank sensor box and part number……..
Re: 2008 3.5L Chrysler Sebring Engine Code Issue [Re: SportFuryS/23383] #3172124
09/01/23 04:40 PM
09/01/23 04:40 PM
Berlin, CT
Confused
Confused
Berlin, CT
Not sure if I mentioned it, but the cam sensor was also replaced……
Re: 2008 3.5L Chrysler Sebring Engine Code Issue [Re: SportFuryS/23383] #3172153
09/01/23 06:55 PM
09/01/23 06:55 PM
Oak Harbor, WA
W
W
Oak Harbor, WA
Did you try to resync the cam and crank sensor using a scan tool? I would also check the camshaft tone ring for issues as well, next step would be to verify the wiring from the camshaft sensor and the crankshaft sensor to the pcm wiggling the wiring harness while watching your omh meter.
