Remote water pump RB? #3166934
08/09/23 08:55 PM
08/09/23 08:55 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
Who on here runs a remote water pump on a RB engine? What do you use to adapt the AN hoses to the block? I know that Andy F made some but has discontinued making them. Shogun made a kit many years ago that was two tubes on a flange for each side and a AN fitting on either tube. This was advertised as a reverse flow system. They are no longer in business. CSI (changed to CSR later) made a water pump kit (in the mid 1990's) that used two alum blocks connected by a 1.25" tube with a upper radiator hose connection all made together. This system used a SB Chevy electric water pump that bolted to the alum blocks. This is also no longer available. Indy has a reverse flow manifold that could possibly work, but I don't think that it has a provision for a coolant temp sensor?
Any help or Ideas short of making something from scratch greatly appreciated.
Also, if anyone has one of these obsoleted items laying around, please PM me, I would be interested in them.
Thanks, Brian
Re: Remote water pump RB? [Re: '72CudaRacer] #3166942
08/09/23 09:08 PM
08/09/23 09:08 PM
Boise
Moparteacher Offline
Boise
I don't run a remote pump, but I do have AN hoses. I had a 16AN bung welded to the inley of the aluminum waterpump. The t-stat as a Chevy 16AN outlet from a circle track store. I had the housing bored to recess the t-stat about 3/4" below and then set a spacer on top to keep it in position. I had a bung welded to the radiator, the other hose has a threaded 16AN fitting.
I have a reverse flow Meziere waterpump with 16AN fittings I ran on the last engine. FLIW, I probably should have gone with AN 20.
Re: Remote water pump RB? [Re: '72CudaRacer] #3166948
08/09/23 09:46 PM
08/09/23 09:46 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Remote water pump RB? [Re: '72CudaRacer] #3166953
08/09/23 10:08 PM
08/09/23 10:08 PM
AndyF Offline
AndyF  Offline
I sell the blocks to Indy who sell them with their own name on them. I don't sell them under my own name anymore.
Re: Remote water pump RB? [Re: AndyF] #3167001
08/10/23 08:37 AM
08/10/23 08:37 AM
Mooresburg, Tn
Mooresburg, Tn
Sorry Andy, I misunderstood what you told me about making them. Is there enough "meat" there to install a temp sending unit?
Thanks, Brian
Re: Remote water pump RB? [Re: '72CudaRacer] #3167010
08/10/23 09:16 AM
08/10/23 09:16 AM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
Mezeire makes a adapters WP84S for AN fittings on the block. They also make water neck spacers with holes for sending unit.
I ran the Indy Plate with a Mez SBC pump, still have it if anyone is interested.
Good Luck
Re: Remote water pump RB? [Re: '72CudaRacer] #3167036
08/10/23 10:39 AM
08/10/23 10:39 AM
AndyF Offline
AndyF  Offline
Yes, there is plenty of room for a temp sending unit
Re: Remote water pump RB? [Re: '72CudaRacer] #3167052
08/10/23 12:05 PM
08/10/23 12:05 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have run remote or radiator mounted pumps for years. I usually put them temp sensor in the radiator personally. It can get a bit busy with plumbing for sure.
Meziere makes block adapters and they work great. I have a buddy in Idaho who makes them for me as well but have used both. I also use their pumps.
https://www.meziere.com/Products/Co...k-Adapter-Set-BB-Mopar-to-12-female.aspx
Radiator mounted pump with block adapters on the Stratus
On my Dakota
Re: Remote water pump RB? [Re: Al_Alguire] #3167541
08/12/23 09:33 PM
08/12/23 09:33 PM
AZLIVN
SLO-KID Offline
SLO-KID  Offline
AZLIVN
Loved my old Sho Gun set up on my RB…… man that was a long time ago!
