Re: Balance slicks
[Re: Thelma133]
#3166418
08/08/23 03:10 AM
08/08/23 03:10 AM
Posts: 43,335 Bend,OR USA
Cab_Burge
I've return more than one new set of slicks due to them taking more than eight ounces to balance them. I have seen a bunch of slicks that were out of round as well as having severe heavy spots on them I was told by one of the west coast racing tire reps that those problems are usually cause by the factory workers taking them out of the molds to soon and letting them set on the tread part of slick making them become mess up like they are, out of round and a bad heavy spot IHTHs
Re: Balance slicks
[Re: DusterKid]
#3166450
08/08/23 09:08 AM
08/08/23 09:08 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I bubble balance every slick that goes on my car.
Re: Balance slicks
[Re: Thelma133]
#3166492
08/08/23 11:17 AM
08/08/23 11:17 AM
Posts: 12,319 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I thought i had fixed my vibration on my 67 cuda. New mark Williams shaft, changed pinion angle, new wishbone. Now, just to be safe, i bought a bubble balancer to check the REAR SLICKS (brand new Goodyear) and it took “26”ounces to balance one tire. The other tire was almost as bad, 16 ounces for that one. I know many of you don’t balance, but the tire installer said he’s sure the goodyears (. And maybe the tubes in them) are defective. I’m awaiting his tear down tomorrow and opinion of what’s wrong. I was running 10 lbs air in the slick and have about 8 passes on them. The vibration shook the entire car, it was bad. I think my problem all along was defective tire and just pissed away 1200 on a new Williams shaft. Any of you running Goodyear have any issues with them????
Thanks 16 ounces?!?!?!? 26 ounces?!?!?!? Those should go right back to the vendor. Another thing to look for that I see all the time is out of round or egg shaped tires. You will feel that in the car and no amount of balancing will cure it. Needing lots and lots of weights is an indication that the tire(s) will more than likely be out of round, too. A spin balancer is key to finding the out of rounds before too much time is spent on them. Any significant out of round is a no go for me. They will never get any better and no attempts at balancing will cure the vibration that they cause. I nearly quit buying MTs over these issues and was a big part of my decision to go to the 275 drag radials rather than the 295s. All of the 295s were just about unusable. At least I can find 275s that don't totally shake my fillings out. And bolt up your wheels to the car and check that run-out, too. I have seen aftermarket axles and rims that were terrible.
Master, again and still
Re: Balance slicks
[Re: DaveRS23]
#3166579
08/08/23 03:16 PM
08/08/23 03:16 PM
Posts: 2,527 PA
moparacer
PA
I bet its not the tires, its something with the balancing. Both being off that much......26 ounces on one?!?!? Never do that, figure out what is wrong.
All the years I have raced I never seen any slick from the big 3 take any more than 8.
I bubble balance mine with a cheap harbor freight balancer. Been doing that way for years.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: Balance slicks
[Re: FastmOp]
#3166697
08/08/23 11:50 PM
08/08/23 11:50 PM
Posts: 165 Kansas
Thelma133
Kansas
Thanks to all of you that gave me your thoughts. The guy that repaired the horrible balance job and sells Hoosiers, not Goodyear, (he does pro stock and pro mod balancing at NHRA events) told me the tubes were twisted in numerous spots. One of them he said was really bad. After he installed new tubes, one tire took half an ounce, the other, an ounce. That sounds hopeful to me, but I don’t think I’ll buy Goodyear anymore. I always had good luck with Hoosiers. Yes, I do have my fingers crossed. As I side note, I took the tires off because I noticed that one slick had no weights at all, it was the 26 ouncer. If you set this tire on the ground, it would roll away from you.
Thanks again
Re: Balance slicks
[Re: Cab_Burge]
#3166729
08/09/23 07:33 AM
08/09/23 07:33 AM
Posts: 2,567 S.E. Michigan
cl440
S.E. Michigan
I've return more tyhan one new set of slicks due to them taking mor e than eight ounces to balance them. I have seen a bunch of slicks that were out of round as well as having severe heavy spots on them I was told by one of the west coast racing tire reps that those problems are usually cause by the factory workers taking them out of the molds to soon and letting them set on the tread part of slick making them become mess up like they are, out of round and a bad heavy spot IHTHs We had a set one time and one of the slicks needed a ridiculous amount of weight to even get it close and it still had a vibration. We sent them back! The most I have ever ran on a slick is a pound which to me is way to much weight.
Re: Balance slicks
[Re: cl440]
#3166851
08/09/23 03:04 PM
08/09/23 03:04 PM
Posts: 4,587 Motor City
6PKRTSE
Motor City
I bubble balance my slicks and drag radials.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: Balance slicks
[Re: Gabby63]
#3166956
08/09/23 10:14 PM
08/09/23 10:14 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I always balance slicks simply because the balancer is right next to the tire machine I use to mount them so it's a no brainer for me. We have a really nice road force balancer at the dealership where I work that also measures the exact tire diameter as well. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Balance slicks
[Re: fourgearsavoy]
#3167059
08/10/23 12:18 PM
08/10/23 12:18 PM
Posts: 19,391 Las Vegas
Al_Alguire
Las Vegas
For those who religiously balance their slicks have you ever put them on the balancer after a couple races?
Re: Balance slicks
[Re: coronetville]
#3167297
08/11/23 03:50 PM
08/11/23 03:50 PM
Posts: 3,473 Dandridge TN
Dabee
Dandridge TN
after installing any tubes in any tires take center out of valve stem and fill and let out air many many times to untwist any twisted tubes, yes I know you allready know this I always dump lots of baby powder I my slicks with tubes. Never had a problem with twisted tubes. Also used a harbor freight bubble balancer.
