Need help with a starter issue #316626
05/13/09 12:43 AM
05/13/09 12:43 AM
Frederick, MD
moparguy1967 Offline OP
Frederick, MD
I have purchased a mini starter to use with my 360 magnum/ 904 combo. The starter is a late model dodge stater from AutoZ***. I dont know why, but it just does not seem to fit. The nose of the starter does not even reach the pilot in the trans case. Are their more then one style of mini stater? If yes, then what is the best year and model vehicle to use. I need to get a starter locally. Im trying to get it finished, so I can take it to Ocean City for the car cruise. Thanks for any help in advance.
Re: Need help with a starter issue [Re: moparguy1967] #316627
05/13/09 12:48 AM
05/13/09 12:48 AM
Frederick, MD
Frederick, MD
I read the tech archives and I still dont know why Im having my problem.
Re: Need help with a starter issue [Re: moparguy1967] #316628
05/13/09 01:14 AM
05/13/09 01:14 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Do you have one that fit before?
Maybe measure or side by side compare the snout and see if the dimensions are the same.
Re: Need help with a starter issue [Re: moparguy1967] #316629
05/13/09 06:46 AM
05/13/09 06:46 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
The mini starter has to be from a 3.9 (V6), 5.2 (318), or 5.9 (360) truck. The front wheel drive engine starters won't fit.
Re: Need help with a starter issue [Re: moparguy1967] #316630
05/13/09 07:30 AM
05/13/09 07:30 AM
Slidell, La.
doctor_mopar Offline
Slidell, La.
By my recollection, the nose does not go in the pilot of the trans . It only has to match up with the two bolts and fit flush to the case. The starter you need is for an application like the 318/360 from about 1990 up.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Need help with a starter issue [Re: doctor_mopar] #316631
05/13/09 08:44 AM
05/13/09 08:44 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I bought a new mini starter on ebay and the guy swore it would fit my small block but the nose wouldn`t go into the recess in the bell housing. I measured it and compared it to the old one. It was a a little too big. He sent me another one and that one fit.
Re: Need help with a starter issue [Re: doctor_mopar] #316632
05/13/09 08:53 AM
05/13/09 08:53 AM
Upper Midwest
Upper Midwest
And 3.9 V6. this engine is a 318 based engine.
Yes the nose goes into the pilot. This is helps give the starter support while starting, keeping it in alignment.
