Page 2 of 3 1 2 3
Re: Cam prices [Re: moparacer] #3165269
08/03/23 10:07 AM
08/03/23 10:07 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
@Dwayne - Is this an option for non-LS cams now? https://www.youtube.com/watch?v=hTyIQxrPCCI
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Cam prices [Re: moparacer] #3165272
08/03/23 10:15 AM
08/03/23 10:15 AM
PA
Scully Offline
Scully  Offline
PA
Originally Posted by moparacer
I have had Midway performance (Predator cams) in Mt Carmel PA clean up or regrind several cams for me over the years.
Are they still open, I drive past there at night a couple of time a week, never been inside.
Re: Cam prices [Re: Brad_Haak] #3165287
08/03/23 12:12 PM
08/03/23 12:12 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
I’ll have to ask.
Re: Cam prices [Re: fast68plymouth] #3165538
08/04/23 10:56 AM
08/04/23 10:56 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
I’ll have to ask.
Also do they re heattreat?
Also can Comp nitride a custom I have that originally was not , hasn't been installed yet ?
Mainstream Media is the new Pravda
Re: Cam prices [Re: JohnRR] #3165542
08/04/23 11:06 AM
08/04/23 11:06 AM
So. Burlington, Vt.
So. Burlington, Vt.
You can’t nitride a cam that’s already been parkerized, so..... no.
The cam cores are heat treated prior to putting the finish profile on them.
The heat treat is part of the manufacturing process of making the “semi-finished” core that most cams start out as.
Re: Cam prices [Re: Scully] #3165547
08/04/23 11:45 AM
08/04/23 11:45 AM
PA
moparacer Offline
moparacer  Offline
PA
They still have the ebay store up so I assume they are? I had them bush a block in the middle of the pandemic. 2020 or so.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Cam prices [Re: A727Tflite] #3165764
08/05/23 03:21 PM
08/05/23 03:21 PM
AndyF Offline
AndyF  Offline
The rollers have snuck up a little here and there.
The FT’s went up like $95 over night(my cost).
For some reason, the “street” FT cams are still less $$$........ but still saw a noticeable increase.
New question - who regrinds roller camshafts?
I have a couple older Crane and Cam Dynamics rollers that have bad scuffed lobes.
All are .750” lift - was wondering if you may have the answer to this regrind question.
Oregon Cam Grinding will take a roller cam and redo it. They have a big list of masters and they can usually get close to what you need.
Re: Cam prices [Re: fast68plymouth] #3165765
08/05/23 03:22 PM
08/05/23 03:22 PM
AndyF Offline
AndyF  Offline
I just received a custom solid roller from Kaase for the 521 project. Cost was $525. He sells solid roller lifters that are built to his specs for $575 so the cam was a little more expensive than usual, but the lifters were less expensive than I was expecting.
Re: Cam prices [Re: fast68plymouth] #3166197
08/07/23 10:37 AM
08/07/23 10:37 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Thanks , I'll run it with Crower cam savers and hope for the best , the block is bushed so at least the geometry will not be suspect.
Re: Cam prices [Re: JohnRR] #3166205
08/07/23 11:12 AM
08/07/23 11:12 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Is it corrected and bushed or just bushed. Some shops can’t do the correction.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: Cam prices [Re: Brad_Haak] #3166312
08/07/23 03:53 PM
08/07/23 03:53 PM
So. Burlington, Vt.
So. Burlington, Vt.
The word is it can be done to any billet cam.
Re: Cam prices [Re: fast68plymouth] #3166356
08/07/23 07:33 PM
08/07/23 07:33 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Fark the LS motor.. I am so damn tired of hearing about it...
It isn't the end all/be all .
I'm tired of the "stick and LS in it" attitude (whatever"it"may be)
Even the Dakotas and Durango's I've seen stories about LS swaps. And a particular 75 dart...
Re: Cam prices [Re: pittsburghracer] #3166481
08/08/23 10:54 AM
08/08/23 10:54 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
I hope it was corrected fan I searched out a local shop with a Rottler because it was cheaper than shipping them to Florida to Dan/Performance_Only when he was still with us angel
Re: Cam prices [Re: JohnRR] #3166496
08/08/23 11:21 AM
08/08/23 11:21 AM
PA.
"Little"John
"Little"John
PA.
I have the last Chevy sized K1 crank in my 408 in my duster right now. And the 4.5 Calias crank in my 572 that he got me too. I still have a new set of Diamond flat top 408 pistons on a shelf that he got for me. I miss talking to Dan.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.38@138.67
Re: Cam prices [Re: fast68plymouth] #3166744
08/09/23 08:42 AM
08/09/23 08:42 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Any idea what the uncharge is for this service? Not like I'm currently shopping for a cam, but that treatment looks like a good idea to me. Thx
Re: Cam prices [Re: Brad_Haak] #3166758
08/09/23 09:57 AM
08/09/23 09:57 AM
So. Burlington, Vt.
So. Burlington, Vt.
I would say about $125
Re: Cam prices [Re: fast68plymouth] #3166850
08/09/23 03:03 PM
08/09/23 03:03 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My tool steel custom ground solid roller 55MM Hemi nitrous cam was around $700.00 and less than 2 weeks to receive.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Cam prices [Re: 6PKRTSE] #3166867
08/09/23 03:53 PM
08/09/23 03:53 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
just curious who that was from and how long ago?
Re: Cam prices [Re: Al_Alguire] #3166996
08/10/23 08:01 AM
08/10/23 08:01 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
The one guy I know locally who switched his program over to tool steel about 5 years ago WAS paying $1200 and they seem to get some deals in my experience. I'd think that's a more realistic current cost if not more.
Re: Cam prices [Re: Al_Alguire] #3167027
08/10/23 09:54 AM
08/10/23 09:54 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
However, luckily I am better then W.D. with most suppliers buying direct on everything so that helps on everything that I purchase.
Page 2 of 3 1 2 3
