Re: Cam prices
[Re: moparacer]
#3165269
08/03/23 10:07 AM
08/03/23 10:07 AM
Posts: 1,200 Loudoun County, VA
Brad_Haak
Loudoun County, VA
@Dwayne - Is this an option for non-LS cams now? https://www.youtube.com/watch?v=hTyIQxrPCCI
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Cam prices
[Re: moparacer]
#3165272
08/03/23 10:15 AM
08/03/23 10:15 AM
Posts: 201 PA
Scully
PA
I have had Midway performance (Predator cams) in Mt Carmel PA clean up or regrind several cams for me over the years. Are they still open, I drive past there at night a couple of time a week, never been inside.
Re: Cam prices
[Re: JohnRR]
#3165542
08/04/23 11:06 AM
08/04/23 11:06 AM
fast68plymouth
So. Burlington, Vt.
You can’t nitride a cam that’s already been parkerized, so..... no.
The cam cores are heat treated prior to putting the finish profile on them.
The heat treat is part of the manufacturing process of making the “semi-finished” core that most cams start out as.
Re: Cam prices
[Re: Scully]
#3165547
08/04/23 11:45 AM
08/04/23 11:45 AM
Posts: 2,527 PA
moparacer
PA
I have had Midway performance (Predator cams) in Mt Carmel PA clean up or regrind several cams for me over the years. Are they still open, I drive past there at night a couple of time a week, never been inside. They still have the ebay store up so I assume they are? I had them bush a block in the middle of the pandemic. 2020 or so.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: Cam prices
[Re: A727Tflite]
#3165764
08/05/23 03:21 PM
08/05/23 03:21 PM
Posts: 31,096 Oregon
AndyF
The rollers have snuck up a little here and there. The FT’s went up like $95 over night(my cost).
For some reason, the “street” FT cams are still less $$$........ but still saw a noticeable increase. New question - who regrinds roller camshafts? I have a couple older Crane and Cam Dynamics rollers that have bad scuffed lobes. All are .750” lift - was wondering if you may have the answer to this regrind question. Oregon Cam Grinding will take a roller cam and redo it. They have a big list of masters and they can usually get close to what you need.
Re: Cam prices
[Re: fast68plymouth]
#3166197
08/07/23 10:37 AM
08/07/23 10:37 AM
Posts: 75,106 A Banana Republic near you.
JohnRR
Thanks , I'll run it with Crower cam savers and hope for the best , the block is bushed so at least the geometry will not be suspect.
Re: Cam prices
[Re: JohnRR]
#3166205
08/07/23 11:12 AM
08/07/23 11:12 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks , I'll run it with Crower cam savers and hope for the best , the block is bushed so at least the geometry will not be suspect. Is it corrected and bushed or just bushed. Some shops can’t do the correction.
Re: Cam prices
[Re: pittsburghracer]
#3166481
08/08/23 10:54 AM
08/08/23 10:54 AM
JohnRR
Thanks , I'll run it with Crower cam savers and hope for the best , the block is bushed so at least the geometry will not be suspect. Is it corrected and bushed or just bushed. Some shops can’t do the correction. I hope it was corrected ![fan fan](/ubbthreads/images/graemlins/custom/fan.gif) I searched out a local shop with a Rottler because it was cheaper than shipping them to Florida to Dan/Performance_Only when he was still with us ![angel angel](/ubbthreads/images/graemlins/custom/angel.gif)
Re: Cam prices
[Re: JohnRR]
#3166496
08/08/23 11:21 AM
08/08/23 11:21 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks , I'll run it with Crower cam savers and hope for the best , the block is bushed so at least the geometry will not be suspect. Is it corrected and bushed or just bushed. Some shops can’t do the correction. I hope it was corrected ![fan fan](/ubbthreads/images/graemlins/custom/fan.gif) I searched out a local shop with a Rottler because it was cheaper than shipping them to Florida to Dan/Performance_Only when he was still with us I have the last Chevy sized K1 crank in my 408 in my duster right now. And the 4.5 Calias crank in my 572 that he got me too. I still have a new set of Diamond flat top 408 pistons on a shelf that he got for me. I miss talking to Dan.
Re: Cam prices
#3166744
08/09/23 08:42 AM
08/09/23 08:42 AM
Brad_Haak
Loudoun County, VA
The word is it can be done to any billet cam. Any idea what the uncharge is for this service? Not like I'm currently shopping for a cam, but that treatment looks like a good idea to me. Thx
Re: Cam prices
#3166850
08/09/23 03:03 PM
08/09/23 03:03 PM
Posts: 4,587 Motor City
6PKRTSE
Motor City
My tool steel custom ground solid roller 55MM Hemi nitrous cam was around $700.00 and less than 2 weeks to receive.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: Cam prices
[Re: 6PKRTSE]
#3166867
08/09/23 03:53 PM
08/09/23 03:53 PM
Posts: 19,388 Las Vegas
Al_Alguire
Las Vegas
My tool steel custom ground solid roller 55MM Hemi nitrous cam was around $700.00 and less than 2 weeks to receive. just curious who that was from and how long ago?
Re: Cam prices
[Re: Al_Alguire]
#3166996
08/10/23 08:01 AM
08/10/23 08:01 AM
Posts: 4,101 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
My tool steel custom ground solid roller 55MM Hemi nitrous cam was around $700.00 and less than 2 weeks to receive. just curious who that was from and how long ago? The one guy I know locally who switched his program over to tool steel about 5 years ago WAS paying $1200 and they seem to get some deals in my experience. I'd think that's a more realistic current cost if not more.
Re: Cam prices
[Re: Al_Alguire]
#3167027
08/10/23 09:54 AM
08/10/23 09:54 AM
6PKRTSE
Motor City
My tool steel custom ground solid roller 55MM Hemi nitrous cam was around $700.00 and less than 2 weeks to receive. just curious who that was from and how long ago? However, luckily I am better then W.D. with most suppliers buying direct on everything so that helps on everything that I purchase.
