Re: Oil Weight for big cube street / strip Motor
[Re: AndyF]
#3163778
07/27/23 11:54 PM
07/27/23 11:54 PM
Posts: 712 California
BigDaddy440
California
Depends on the clearances used when building the motor. Typically bigger clearances need heavier oil. Exactly. Most new cars are running thin synthetics, but their bearing clearances are tighter. As an example, if your clearances are say .0025" on the mains and .002" on the rods, that's a little looser than most engines came from the factory, and you're okay running a medium weight oil, like 10w-30 or just 30w if you want something a little thicker. If you're engine was built loose like some racier engines are, say .003"-.0035" on the mains and .0025" on the rods, I would think you may want to run a heavier oil. I also like the idea of running an oil with zinc, even on a roller cam motor that may not require it.
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: BigDaddy440]
#3163785
07/28/23 12:17 AM
07/28/23 12:17 AM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
Penn Grade 20/50 in my 505 wedge . If you are sitting peak hour traffic for extended periods or extended highway use heavier oil may be a good thing . I do run a solid flat tappet cam . JMO .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: AndyF]
#3163804
07/28/23 08:11 AM
07/28/23 08:11 AM
Posts: 12,410 Taxes & Virus's R-US, NY
Dragula
Depends on the clearances used when building the motor. Typically bigger clearances need heavier oil. My piston to wall clearance on this one is tighter than previous, but most are about .003" for clearances. I typically run Brad Penn 20-50 and was wondering if I should switch to straight 50w? I burned #7 bearing last year again, so I do not want to do that again.
[Re: Dragula]
#3163812
07/28/23 08:44 AM
07/28/23 08:44 AM
Posts: 1,763 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
I would think you'd want to run (ideally) the thinest oil that will get you the pressure you need.
Idea here being:
1) any system leaks will bleed the pressure 2) thinner oil will make that bleed easier to happen: the thinner it is the easier it will be for it to escapte through any such path 3) of course you need volume to carry the heat away, so pressure isn't the only metric to watch, but as far as leaks go it's a darn good indicator
My stroker motor has: 1) 0.032 - 0.035" clearance on the MAINS 2) 0.020 - 0.023" clearnace on the RODS
I intend to run VR1 10W30, but if that nets me an uncomfortably low pressure I'll move up to 10W40, or 15W40.
Right now the crankcase is full of break-in oil (30), only 1 startup so far, but it was a steady 45-50 at idle and 75 at the initial start and about 2K RPM.
I found this DRIVEN reference chart to be pretty handy, take a look at the attachment.
[Re: Dragula]
#3163820
07/28/23 09:27 AM
07/28/23 09:27 AM
Posts: 12,233 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
540 street/strip Hemi, and 499" street/strip wedge. Used to run 20-50, then tried the 15-40, and then tried the 10-30.
Valvoline VR-1 10-30 is what has been in both engines the last few years. No synthetic, no additives. Both engines have SFT cams. Good hot pressure and no problems.
Master, again and still
[Re: DaveRS23]
#3163826
07/28/23 10:04 AM
07/28/23 10:04 AM
Posts: 4,694 Wichita
GY3
Wichita
I use 20w50 VR1 and have used Brad Penn in the past.
I primarily use that weight it because we use nitrous and try to absorb the shock a little better.
I pulled it apart a couple of winters ago and was surprised at how well the bearings and the main caps looked! Almost no fretting on the caps and the bearings had virtually no wear.
This is all on a stock block with studs and spraying 250 shot.
[Re: GY3]
#3163840
07/28/23 11:08 AM
07/28/23 11:08 AM
Posts: 8,182 Plymouth, MI
Blusmbl
Plymouth, MI
I use 15W50 but also try to make sure the engine has some oil temperature in it before making passes. Thinner oils are better if you don't spend any time warming it up at the track for sure. The thicker and/or straight weight oils don't flow as well cold. In some other applications we've failed engines with heavier weights at cold ambient temps because while it has pressure, the oil isn't flowing to all of the appropriate bearing surfaces.
[Re: Blusmbl]
#3163847
07/28/23 11:22 AM
07/28/23 11:22 AM
GY3
Wichita
I use 15W50 but also try to make sure the engine has some oil temperature in it before making passes. Thinner oils are better if you don't spend any time warming it up at the track for sure. The thicker and/or straight weight oils don't flow as well cold. In some other applications we've failed engines with heavier weights at cold ambient temps because while it has pressure, the oil isn't flowing to all of the appropriate bearing surfaces. Yep, even after a brief warmup down the return road, the car will usually gain quite a bit due to all the oils and lube being warmed up after a pass.
[Re: Cab_Burge]
#3163873
07/28/23 12:44 PM
07/28/23 12:44 PM
Posts: 19,380 Las Vegas
Al_Alguire
Las Vegas
Driven XP3 in everything for me. Street car and racecars, all aluminum blocks.
[Re: Blusmbl]
#3163879
07/28/23 01:16 PM
07/28/23 01:16 PM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
I use 15W50 but also try to make sure the engine has some oil temperature in it before making passes. Thinner oils are better if you don't spend any time warming it up at the track for sure. The thicker and/or straight weight oils don't flow as well cold. In some other applications we've failed engines with heavier weights at cold ambient temps because while it has pressure, the oil isn't flowing to all of the appropriate bearing surfaces. I try to run as thin as possible. Thin enough to have 15-20psi at hot idle but also not have 100PSI through the traps once the oil cools off from the drive. My car is faster the cooler I can run it so I try to keep the engine as cool as possible. I normally try to hit the burnout box at 140 coolant temp, it slows down .1 if I hit the box at 160. Stupid naturally aspirated racing lol.
68 Barracuda Formula S 340
