Re: 727 trans fluid fill procedure ?
[Re: krw71ragtop]
#316295
05/12/09 08:32 PM
05/12/09 08:32 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Neutral. There is no pump action in Park. Fill to the full mark, get warm and run through the gears and then check the fluid level and fill to the full mark.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: MoparforLife]
#316296
05/12/09 09:20 PM
05/12/09 09:20 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I always fill the conv before I install it if it's new.
[Re: WILD BILL]
#316298
05/12/09 10:35 PM
05/12/09 10:35 PM
MoparforLife
Upper Midwest
![](/ubbthreads/images/graemlins/iagree.gif)
I agree, but in this case the converter was already installed.
[Re: MoparforLife]
#316299
05/13/09 10:28 AM
05/13/09 10:28 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
uuuum , there IS pump action in park if the engine is RUNNING, and there is cooler circuit flow just no where near the amount in neutral, BUT yes start it in neutral. I usually dump a quart in the convertor before sticking it on the trans so it's not dry on start up.
