Re: 'glide question
[Re: mopar873]
#3162732
07/24/23 01:04 PM
07/24/23 01:04 PM
Posts: 19,369 Las Vegas
Al_Alguire
Las Vegas
No reason for there to be a clean neutral in a glide. As stated no one makes a reverse pattern either. A stock glide actually holds up to a fair amount of power. Weakest link is the stock planetaries but they work just fine to 800hp or so. I would likely replace them at anything over 700 myself. Wouls also buy a good brake valvebody. Just in case you want to go that way at a later date.
Re: 'glide question
[Re: Al_Alguire]
#3162740
07/24/23 01:14 PM
07/24/23 01:14 PM
Posts: 11,596 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Any good Glide VB will likely need to have the TB button used to engage the reverse clutches and get it to back up. Doesn't mean you have to use the brake to leave.
Small block at that weight with a 1.76 is going to require an aggressive 4 link base line. Yes, you can spin the tires because the suspension is not aggressive enough to apply them.
Car will probably want a 1.96/1.98 to be happy.
Re: 'glide question
[Re: CMcAllister]
#3162755
07/24/23 01:51 PM
07/24/23 01:51 PM
Posts: 191 WI
mopar873
WI
Good tip on the 4 link. Apparently the Coan VB will operate reverse fine with the TB unplugged.
Re: 'glide question
[Re: mopar873]
#3162767
07/24/23 02:02 PM
07/24/23 02:02 PM
Al_Alguire
Las Vegas
Any non Pro brake should work fine with not having to engage the brake to back up.
