Trans help! Po740 & Po783 #3162682
07/24/23 11:35 AM
07/24/23 11:35 AM
sc
tjmarcus1 Offline OP
sc
[b][/b] 97 Ram1500 convertor not locking and not shifting into 4th.
Re: Trans help! Po740 & Po783 [Re: tjmarcus1] #3162700
07/24/23 12:11 PM
07/24/23 12:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Torque Converter Clutch is what the codes point to. For future reference the code is p zero not p o.It makes a difference when looking them up. This might help. https://www.youtube.com/watch?v=X9fIKys_9SI
Re: Trans help! Po740 & Po783 [Re: tjmarcus1] #3168043
08/15/23 10:28 AM
08/15/23 10:28 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Both of those functions are performed by electronically controlled solenoids.
Re: Trans help! Po740 & Po783 [Re: JohnRR] #3168156
08/15/23 07:34 PM
08/15/23 07:34 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
There was a wire corrosion problem between the trans relay and the solenoid plug. Pull the plug at the trans and check to see if one terminal has 12 volts, and one terminal has 5 volts. (which terminals have which voltage depends on the year). If the 12 volts are missing, that power comes from the relay, if the 5 volts are missing, that comes from the ECM. The bad wire splice is near the top of the trans on the wires going to the solenoid plug, at the firewall.
