Re: Help me get my combo to 7.50 on the to 1/8 [Re: B3422W5] #3162527
07/23/23 07:36 PM
07/23/23 07:36 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
But then, once the OP starts hitting the drive train and tires that much harder, he will need to do other things. Maybe a lot of other things.
Master, again and still
Re: Help me get my combo to 7.50 on the to 1/8 [Re: DaveRS23] #3162579
07/23/23 10:23 PM
07/23/23 10:23 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Converter and gears, my 64 all steel savoy with a 73 440 stock pistons, 509 cam, torker intake, 750 Holly, stock 452 heads, TA 3800 vert, 4.88 gears, 14/32 slicks ran 7.50s all day. My 60 was in the 1.60 range and run regular pump gas (8 to 1 ratio pistons) done at 5000 rpm.
Re: Help me get my combo to 7.50 on the to 1/8 [Re: belvedere1967] #3162646
07/24/23 09:37 AM
07/24/23 09:37 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Gears and torque converter. You want the stall to start at the beginning of the torque curve and the car to cross the finish line at max HP RPM. If you don't have real dyno numbers use a good computer program and put good numbers into it, that will give you the info to buy gears and a converter. After the gears and converter then start tweaking the small stuff like timing, carb jets, and shocks. decent 90/10 on the front, clamping leaf springs, and a decent adjustable shock on the rear. You should get way down in the 7's
Re: Help me get my combo to 7.50 on the to 1/8 [Re: jwb123] #3162652
07/24/23 09:53 AM
07/24/23 09:53 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Forgot, make car lighter
Re: Help me get my combo to 7.50 on the to 1/8 [Re: cudaman1969] #3162919
07/24/23 09:59 PM
07/24/23 09:59 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
As suggested above the Wallace Calculators are very helpful.
Here is are your target numbers
60 Foot 1.65
330 Foot 4.77
660 Foot 7.50
660 MPH 90.63
1000 Foot 9.87
1/4 Mile ET 11.89
1/4 Mile MPH 111.48
If you put your current best 1.80/7.99/84 one piece at a time into the ideal calculator you can begin to see a little of the picture.
At a 7.99 you should 60 - 1.76 and mph 85.07
At a 1.80 you should et 8.17 and mph 83.19
At 84 mph you should 60 - 1.78 and et 8.09
So your ET and mph are good for your 60 ft
However, you have a low enough ET you should 60 ft and MPH better.
At 3,800lbs you need about 400HP at the wheels to go 7.50, so with an automatic probably right at 500 at the crank (again as mentioned above). Based on your 7.99 at 3800lbs you would need about 85 more crank HP as you are making a little over 400 at the crank now. I would do a quick leak-down and compression test to see what you are starting with, once I knew I had a solid bottom, I would give Dwayne a call and have him spec you a cam. You didn't mention compression or rpm so those are big factors. Once you get a better feel for your power curve, you can gear and converter it to make it work together (as it is likely you will need more of both).
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Help me get my combo to 7.50 on the to 1/8 [Re: clovis] #3162953
07/25/23 04:50 AM
07/25/23 04:50 AM
gregsdart Offline
gregsdart  Offline
Do you have a cold air intake system of any sort? Collecter extensions? At least an 18 inch to 24 inch collecter on a car with a tight converter like you have. You didn't say how you ran the car. Open exhaust, or not?
Re: Help me get my combo to 7.50 on the to 1/8 [Re: clovis] #3162984
07/25/23 09:33 AM
07/25/23 09:33 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
60 Foot 1.65
330 Foot 4.77
660 Foot 7.50
660 MPH 90.63
1000 Foot 9.87
1/4 Mile ET 11.89
1/4 Mile MPH 111.48
That is good information. But I would suggest getting the 60' down to the 1.6 area first. That, by itself will help the ET significantly and probably reduce how much more power was needed to get on down to 7.5. And the improvements done for that would be necessary anyway after additional power was added because adding power first could possibly make the 60' worse rather than better.
Re: Help me get my combo to 7.50 on the to 1/8 [Re: DaveRS23] #3163207
07/25/23 09:14 PM
07/25/23 09:14 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I'd throw a huge converter in it 😂
Re: Help me get my combo to 7.50 on the to 1/8 [Re: belvedere1967] #3165296
08/03/23 12:55 PM
08/03/23 12:55 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
I'm a little late to the party, but you sould ditch the TM7 intake and put a Performer RPM on it.
Re: Help me get my combo to 7.50 on the to 1/8 [Re: cudaman1969] #3165331
08/03/23 02:58 PM
08/03/23 02:58 PM
iagree wrench scope
Generally for each hundred pounds of weight remove the car should pick up .10 ET (one tenth) and 1 mph. A good lightweight front bumper and hood will get you near 100 lbs. Take yours off and weigh them and then shop around, I'm not sure what year your car is so the availability of those parts might be limited base on which year car yours is scope up
BTW, a good converter can make a huge difference, I'm seen .6 ET gain from a stock street hemi converter to a good 8 inch race converter that work well on the street also boogie up
Re: Help me get my combo to 7.50 on the to 1/8 [Re: Cab_Burge] #3165341
08/03/23 03:28 PM
08/03/23 03:28 PM
moparx Online content
moparx  Online Content
at what et does the 100lbs per 10th rule start to peter out and added horsepower take over ?
maybe i'm not thinking this through correctly ? shruggy [wouldn't be the first time........]
beer
Re: Help me get my combo to 7.50 on the to 1/8 [Re: moparx] #3165403
08/03/23 07:47 PM
08/03/23 07:47 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
beer
It's always HP/Weight. Obviously 500hp in a 3500. (7.0 weight to 1 hp) car wont make the same change as 1000 hp in a 2500lb car (2.5 weight to 1 hp). I can tell you that my car at 3350 and aprox 900 uncorrected hp that 10lbs/ .01 is damn close.
Doug
Re: Help me get my combo to 7.50 on the to 1/8 [Re: dvw] #3180687
10/03/23 07:00 PM
10/03/23 07:00 PM
alabama
belvedere1967 Offline OP
alabama
Ok so the money wasen't there for the converter yet,so installed the heads .
Best 7.75 @88.7 mph
Re: Help me get my combo to 7.50 on the to 1/8 [Re: belvedere1967] #3180692
10/03/23 07:27 PM
10/03/23 07:27 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Sure, HP/Weight, but putting that HP to work - converter & gears - matters, no ?
OP shouldn't feel too bad in any case: I have a buddy with a SB stick '57 Chevy...can't get it out of the mid 8s in the 1/8 despite spending many thousands on all kinds of stuff.
5-something rear gear, Cal-Tracs, faceplated, slicks, trick carb, spendy engine, etc etc. - though he's adamant about running a the 350-horse cam - so it sounds tame, I guess.
He's an old FC racer who knows his way around a racecar, too, so I'm baffled.
After a few years of hearing about it, I finally told him my 292-inch '57 ran 12.80s in the early '70s, with a helluva lot less $$$ & street tires stirthepot laugh2
Re: Help me get my combo to 7.50 on the to 1/8 [Re: belvedere1967] #3180726
10/03/23 08:20 PM
10/03/23 08:20 PM
A727Tflite Online content
A727Tflite  Online Content
Originally Posted by belvedere1967
I do not have a way to log it but I'm thinking it flashes around 2800
If you truly have a 175 K converter than you are making less than 280 ft. Lbs. of torque.
Something is way off in the engine or you’re stall speed estimate is way off.
