Re: The famous BALLAST RESISTOR!!! [Re: topside] #3162690
07/24/23 10:48 AM
07/24/23 10:48 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iI've had the best luck with MSD blaster II coils. I also have a new one in the box, PM if interested wink
Re: The famous BALLAST RESISTOR!!! [Re: Sinitro] #3162847
07/24/23 04:33 PM
07/24/23 04:33 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Originally Posted by Sinitro
In the START position, U should have 12V on both ballast resistor terminals.
In the RUN position, U should have 12V on the ballast resistor input terminal and 8-9V on the output terminal.
Just my $0.02... wink
50% correct.
In START you get the voltage reading reversed to the RUN position. Hence why the brake light (and oil if present) dims out while cranking. They are feeded from the RUN circuit throught the ballast.
Re: The famous BALLAST RESISTOR!!! [Re: NachoRT74] #3162849
07/24/23 04:36 PM
07/24/23 04:36 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
50% correct.
In START you get the voltage reading reversed to the RUN position. Hence why the brake light (and oil if present) dims out while cranking. They (brake and oil light) are feeded from the RUN circuit throught the ballast.
Clarified that. Though Sinitro is correct in respect to voltage going to the coil.
