Re: How "wild & crazy" have you gone w/ converter for street?
[Re: B3422W5]
#3162658
07/24/23 10:16 AM
07/24/23 10:16 AM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
UNLESS your daily driving it / commuting with it ...... who really cares?? Get the best converter that works at the track , get a decent cooler on it and a trans temp gauge. Street cruise it.... thats what i would do ..... Agree 100%… converter technology has come a long ways. I have never run anything but 8 inch converter suited to best Et at the track, and everything I have had in the last 30 years has been street/ strip. Good cooler, have fun. Run what the combo needs to go fast. With a decent trans cooler it'll be fine on the street. I've run a couple of different 5000-5200 converters on the street w/ no issues.
[Re: an8sec70cuda]
#3163270
07/26/23 07:51 AM
07/26/23 07:51 AM
Posts: 1,189 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Like Fred from Scooby Doo says: Hey, gang, I have a plan!
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3163273
07/26/23 07:59 AM
07/26/23 07:59 AM
Posts: 8,186 Plymouth, MI
Blusmbl
Plymouth, MI
I have a 9" Ultimate in my car, it flashes around 4500 at launch and is ~5k minimum going down the track on nitrous passes. No issues with trans temp, the fluid always looks perfect and I've put thousands of miles on it, including a 700 mile drag and drive last month. I do use ATI synthetic type F though. It cruises fine with 2-3% slip at moderate freeway speeds. 30" tall tire and 4.10's. As long as you can live with the slightly disconnected feeling at low speeds I wouldn't worry at all.
[Re: Brad_Haak]
#3163282
07/26/23 08:52 AM
07/26/23 08:52 AM
Posts: 17,915 S.E. Michigan
ZIPPY
S.E. Michigan
I have a Turbo Action "J" converter that was custom built for a completely different combination, totally unrelated to mine (572ci, high compression nitrous A body). According to Paul at TA it's built as tight as they can possibly make that configuration. It's only around 4500 flash with my wimpy street combination.
Overall I do like it, but I've found the more I load the vehicle down the less I like it.
Back in the days of dragging around two extra wheels and tires, full size steel floor jack, jack stands, couple tool boxes, etc etc etc (And then hope like hell Blusmbl would show up and help me change the tires), it did feel pretty darn sloppy after an hour and a half on M59 and 23 commuting to and from Milan in the summer heat. The rest of the time, no complaints. Driving a shorter distance to and from Lapeer and NOT changing tires, and not hauling tons of extra stuff around, I get along with it much better. Normal cruising without a big payload, it's good.
If anything I'll be adding weight to the car, and 451ci to 572ci is a substantial jump, but I'll try it with the big motor to see if I can get along with it.
Honestly I'd prefer it to be tighter for driving around, and maybe a 572 ci street engine doesn't need all that stall speed, but there's only one way to find out.
Oh, and when I redo the interior I'm putting the 4 speed piece back on the trans tunnel as Chrysler intended. Because.....well, you never know......The pedals are still there..... I'll mount an automatic shifter to it but who knows what might happen later?
Rich H.
Esse Quam Videri
[Re: Uberpube]
#3163563
07/27/23 08:05 AM
07/27/23 08:05 AM
Brad_Haak
Loudoun County, VA
^^^ Not for my car, unless you are funding the initiative
[Re: jim sciortino]
#3163765
07/27/23 10:44 PM
07/27/23 10:44 PM
Posts: 1,229 In The Hills
jughed
In The Hills
Ultimate 8" from Lenny. With a 5.14 rear gear and a 104 rollout tire, it would flash to 7200 rpm, yet was very driveable. Great converters! I run an Ultimate/Lenny 8 1/2" 5500 behind a 540, with 4.10s. Totally street driven. Never had any heating issues with a good cooler and deep pan.
[Re: Brad_Haak]
#3165163
08/02/23 06:22 PM
08/02/23 06:22 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
FWIW, I talked to Sean at Dynamic and asked him if they'd recommend an 8" to better suit the new engine combination than my current 9.5". Surprisingly (to me, at least) he said they'd stick w/ a 9.5" but build it with a different stator (and?) to account for the change in HP & torque curves. I also e-mailed the ATI tech folks asking about one of their 8" Treemaster converters; not sure when I'll hear back on that, but I'm curious what they say. ATI's maybe 60-65 miles from me, so they're not too far away. Myself and friends have had really good success with the Dynamic 9.5 for street and track use, for many years now. They can do a lot with the stator
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: Brad_Haak]
#3165271
08/03/23 10:13 AM
08/03/23 10:13 AM
Brad_Haak
Loudoun County, VA
Like Fred from Scooby Doo says: Hey, gang, I have a plan! I'm purchasing an ATI 8" that Dwayne Porter spec'd originally for a 440 bracket car, but never used. ATI says it's too loose for my application, but the option is always there to have them re-config it w/ different pump & stator, per their Tech Dept.
[Re: Brad_Haak]
#3165292
08/03/23 12:34 PM
08/03/23 12:34 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Like Fred from Scooby Doo says: Hey, gang, I have a plan! I'm purchasing an ATI 8" that Dwayne Porter spec'd originally for a 440 bracket car, but never used. ATI says it's too loose for my application, but the option is always there to have them re-config it w/ different pump & stator, per their Tech Dept. With my experience with ATI if they say its going to be to loose I would be willing to bet its spot on. Every converter I have ever gotten from them for me or a customer was on the tight side.
[Re: AndyF]
#3165340
08/03/23 03:24 PM
08/03/23 03:24 PM
Posts: 19,641 north of coder
moparx
anyone ever use a transbrake converter with a normal manual valve body ? if so, did the converter work ok ? if the converter didn't work out, what was/were the issue/issues with it not working ? just a general question, as i have a converter that was used in a transmission i have now, that i was planning to use. however, i plan to replace the transbrake valve body that is in the transmission now with a normal manual valve body.
[Re: moparx]
#3165406
08/03/23 07:53 PM
08/03/23 07:53 PM
Posts: 9,883 MI, usa
dvw
MI, usa
Just got back from cruising my long dormant street car. Supercharged mild 340, 9.5" PTC 5300 flash, average size trans cooler, generic 2 row aluminum radiator, junkyard electric fan, 4.30 gear, 325/50 radials, 3885lbs with me in it. It's 87 degrees here. Stop and go and a 50 mph cruise. Coolant never went over 195. Trans stayed below 200. Beat on it some to boot. Doug
[Re: dvw]
#3165409
08/03/23 07:58 PM
08/03/23 07:58 PM
Posts: 9,574 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
SAME here on the above
Im pretty fond of my PTC 9.5 vert, hurts many modern car guys feeling when the start talking about there factory 2 step and 7k redline... ha ha ha
STOP POTATO HATE!
[Re: 8urvette]
#3166160
08/07/23 06:44 AM
08/07/23 06:44 AM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
is anyone running one of these 300$+ trans coolers? are they necessary???? I think one of those is better suited when you are running it under the car with no airflow.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3166190
08/07/23 10:10 AM
08/07/23 10:10 AM
an8sec70cuda
I use an old permacool (i think?) trans cooler I bought off the shelf at advance auto parts 25 years ago, lol.
[Re: an8sec70cuda]
#3166204
08/07/23 11:09 AM
08/07/23 11:09 AM
Posts: 10,049 MN
JERICOGTX
MN
I use an old permacool (i think?) trans cooler I bought off the shelf at advance auto parts 25 years ago, lol. What is a "Trans Cooler"??? LOL!!!
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3166244
08/07/23 12:54 PM
08/07/23 12:54 PM
Bad340fish
Tulsa OK
I use an old permacool (i think?) trans cooler I bought off the shelf at advance auto parts 25 years ago, lol. What is a "Trans Cooler"??? LOL!!! It is used to keep the dustless fluid cool in the magic viscous torque multiplying device with lightning fast shifts.
