INVISION LCD DASH KIT, 72-76 DUSTER/DART/SCAMP/VALIANT, DIRECT FIT DIGITAL DASH
DESCRIPTION:
Instrumentation is the focal point of any interior. Make your dash stand out from the crowd with the new InVision Digital Dash from AutoMeter. This complete Direct Fit Digital Dash System for the 1972 to 1976 Plymouth/Dodge A-Body is a one model solution for your entire dash. Monitor the speedometer, tachometer, fuel level, oil pressure, water temperature, and volts all in one place. Upgrade your dash with the latest, modern LCD offering from AutoMeter!
Feature Points
Direct-fit instrumentation solution for 1972 to 1976 Plymouth/Dodge A-Body (Duster, Demon, Dart, Scamp, & Valiant) that monitors speedometer, tachometer, water temperature, oil pressure, fuel level, and volts all in a high resolution and colorful display
12.3” LCD display with four user programmable screens
Integrated notifications for high beams and turn signals as well as instrument warnings and a check engine light
Includes universal wiring harness, and sending units for water temperature and oil pressure as well as a joystick for dash customization
Helps identify critical parameters with visual or audible alarms - low fuel level/oil pressure/voltage and high water temperature
Displays output programmable for imperial or metric measurements
Speedometer easily calibrates to OEM or aftermarket vehicle speed sensors and the tachometer is capable of calibrating to many engine types (1-12 cylinders)
User-selectable fuel level resistance ranges designed for OEM and aftermarket sending units
https://www.autometer.com/invision-lcd-dash-kit-72-76-a-body-direct-fit-digital-dash.html
