Re: Large RPM drop from neutral to in gear
[Re: B1MAXX]
#3160987
07/19/23 12:48 PM
07/19/23 12:48 PM
Posts: 19,369 Las Vegas
Al_Alguire
Las Vegas
Vacuum leak, or conveter way to tight can cause it as well as timing and fuel. How far does it fall back on the shift?
[Re: AndyF]
#3161044
07/19/23 02:55 PM
07/19/23 02:55 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Best idle quality...so a big engine like that will want AF at idle in the low 12's, maybe even mid 11's.
Brian Hafliger
[Re: Brian Hafliger]
#3161106
07/19/23 06:13 PM
07/19/23 06:13 PM
Posts: 31,045 Oregon
AndyF
Best idle quality...so a big engine like that will want AF at idle in the low 12's, maybe even mid 11's. Open headers so no way to measure the AF ratio at idle. I just tune it manually for most RPM and most manifold vacuum. It is plenty rich at idle, I can see how much fuel it is using.
[Re: n20mstr]
#3161132
07/19/23 07:50 PM
07/19/23 07:50 PM
Posts: 2,511 PA
moparacer
PA
What is the timing set at? Possible that its lower than you think? This is what I have ran into before. Big engines and big cams need the distributor locked out to help with the idle quality.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: AndyF]
#3161387
07/20/23 05:20 PM
07/20/23 05:20 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I would try to get the idle much lower. Being efi should make that pretty easy.
[Re: TRENDZ]
#3161541
07/21/23 08:30 AM
07/21/23 08:30 AM
Posts: 8,166 Plymouth, MI
Blusmbl
Plymouth, MI
Does whatever EFI system you're using adjust timing to maintain idle speed? All modern stuff does it but I'm not sure about aftermarket EFI. When it drops into gear it should add timing to compensate for the additional load.
[Re: Blusmbl]
#3161545
07/21/23 09:06 AM
07/21/23 09:06 AM
TRENDZ
Milwaukee WI
There would be much less load to compensate for with a lower idle speed. Any decent modern efi system has no problem idling any engine with any cam at 1000 rpm or lower. Now there may be mechanical reasons to have such a high idle speed, like oiling the lifters or whatever. If that’s the case, ignore my advice.
[Re: Blusmbl]
#3161593
07/21/23 11:37 AM
07/21/23 11:37 AM
AndyF
Does whatever EFI system you're using adjust timing to maintain idle speed? All modern stuff does it but I'm not sure about aftermarket EFI. When it drops into gear it should add timing to compensate for the additional load. EFI engines typically have an IAC which is used to control the idle speed. They will also vary the timing to hold a steady idle but this is a race engine with a special throttle body that doesn't have an IAC. The high idle speed is required due to the big cam. It barely runs at 1300 RPM, doesn't smooth out until around 2000 RPM. The EFI goes into closed loop at 2500 RPM since it can't control the engine below that.
[Re: AndyF]
#3161599
07/21/23 11:51 AM
07/21/23 11:51 AM
TRENDZ
Milwaukee WI
Aren’t you using tps based idle? You can blend tps/ map strategies so there is no map fluctuations in the pw calculation. What system is this using?
[Re: TRENDZ]
#3161605
07/21/23 12:15 PM
07/21/23 12:15 PM
Blusmbl
Plymouth, MI
Is there enough difference in map that you can have a large step in base timing between in gear and out of gear? Have something like 15* at neutral idle and 30* at drive idle at the same engine speed?
[Re: Blusmbl]
#3161612
07/21/23 12:37 PM
07/21/23 12:37 PM
Al_Alguire
Las Vegas
600 cubes and a large drop assume its NA. IMO 1000rpm is alot on the shift, certainly leaving ET on the table. I know nothing about EFI other than OE applications but I would check vacuum. But like to see the converter be a bit closer too.
[Re: Blusmbl]
#3161617
07/21/23 12:41 PM
07/21/23 12:41 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
Are you running in Alpha-N or Speed density ? I would assume Alpha-N since it sounds like it doesn't make much of a vacuum signal.
Have you checked the timing map to see if it transitions through a lot of timing changes between RPM in gear and out of gear ?
Could be that you need more idle fuel down low, A/F sensor will be pretty much useless with a lot of overlap and open headers so won't be able to use that for reference.
May just need a lot of idle timing also...
Maybe recheck the fuel calc. parameters and maybe the injector opening time offset, possibly something there.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: Al_Alguire]
#3161669
07/21/23 02:32 PM
07/21/23 02:32 PM
AndyF
600 cubes and a large drop assume its NA. IMO 1000rpm is alot on the shift, certainly leaving ET on the table. I know nothing about EFI other than OE applications but I would check vacuum. But like to see the converter be a bit closer too. I agree, the converter could be a bit looser to keep the engine in a tighter powerband going down the track.
[Re: AndyF]
#3162666
07/24/23 10:51 AM
07/24/23 10:51 AM
TRENDZ
Milwaukee WI
Andy, I don’t know if you got anywhere with this. Maybe I’m on ignore or you discount my experience. Anyway, this situation is totally fixable if you would disclose the ecu brand/ model. I assure you that the engine can idle much lower by using the correct strategies. I’ve been tuning engines with these idle characteristics for longer than most people in the industry. Once you learn how to make a large cam, low compression, odd fire v twin to idle low and even, an 8 cylinder is a piece of cake. Even if the converter is to tight, you could program a staged dump valve for the converter in whatever conditions you desire.
