Re: Tuff Wheel Leather Restoration?
[Re: Remy-Z]
#3161826
07/22/23 07:30 AM
07/22/23 07:30 AM
Posts: 18,160 Mass
DAYCLONA
Mass
[Re: Remy-Z]
#3184901
10/18/23 06:21 PM
10/18/23 06:21 PM
Posts: 4,181 here.
Remy-Z
here.
[Re: Remy-Z]
#3184902
10/18/23 06:23 PM
10/18/23 06:23 PM
Posts: 4,181 here.
Remy-Z
here.
[Re: cudaman1969]
#3190429
11/12/23 12:52 PM
11/12/23 12:52 PM
Posts: 21,845 Kirkland, Washington
Pacnorthcuda
Can the ‘turning’ rubber be fixed? Mine for the Lil Red is that way. I’ve never done it, but it seems the fix would be to inject glue (maybe superglue….wear eye protection!) with a syringe.
[Re: Pacnorthcuda]
#3190558
11/13/23 01:55 AM
11/13/23 01:55 AM
Posts: 823 On the open road
Hrtbkr
On the open road
I've successfully injected RTV using a syringe baster
While outside on the turnpike
They got this new hit tune
Where thrills become as cheap as gas
And gas as cheap as thrills
[Re: Pacnorthcuda]
#3190742
11/13/23 11:49 PM
11/13/23 11:49 PM
Posts: 5,349 Planet Earth
RoadRunnerLuva
Planet Earth
Can the ‘turning’ rubber be fixed? Mine for the Lil Red is that way. I’ve never done it, but it seems the fix would be to inject glue (maybe superglue….wear eye protection!) with a syringe. A friend of mine was doing this very thing (super glue ) back in the 80's.. on a couple Tuff wheels he had in his possession. It worked fine.
Plymouth Makes It!
[Re: Hrtbkr]
#3190809
11/14/23 12:31 PM
11/14/23 12:31 PM
Posts: 4,324 St. Louis, Mo
318 Stroker
St. Louis, Mo
I've successfully injected RTV using a syringe baster Hrtbkr did mine also. Works great! Thanks Bill!
[Re: 318 Stroker]
#3200594
12/29/23 03:46 AM
12/29/23 03:46 AM
Posts: 2 Canada
julianclar
Canada
I understand how important it is to restore something that holds sentimental value. If you're looking to restore the leather grip on your Tuff wheel, you could check out Von Baer. They offer leather products that might help with your restoration. Here's their website https://vonbaer.com/. You could also try reaching out to local car upholstery shops or leather repair experts for assistance. They might be able to restore the grip and even match the red color to your car.
