Re: Fellow Engine Builders: Low RPM Cold Knock
[Re: BigDaddy440]
#3170956
08/28/23 03:19 AM
08/28/23 03:19 AM
Posts: 712 California
BigDaddy440
California
UPDATE! First, thank you to all who offered suggestions. This really had me stumped. Many of you mentioned the flywheel / flex plate. Below is a 2 minute video update showing exactly where the nose was coming from. https://youtu.be/GZzx_uC7blU?si=cxSEXEHNUw8upIj_For those who would prefer reading: The flywheel bolts (not converter bolts) ended up being too long, but long enough that it wasn't noticeable to the eye. They torqued down to spec, but were actually bottoming out in the crankshaft and not pressing against the flywheel hard enough to secure it while running.
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: BigDaddy440]
#3171085
08/28/23 02:05 PM
08/28/23 02:05 PM
Posts: 3,110 Michigan
A727Tflite
UPDATE! First, thank you to all who offered suggestions. This really had me stumped. Many of you mentioned the flywheel / flex plate. Below is a 2 minute video update showing exactly where the nose was coming from. https://youtu.be/GZzx_uC7blU?si=cxSEXEHNUw8upIj_For those who would prefer reading: The flywheel bolts (not converter bolts) ended up being too long, but long enough that it wasn't noticeable to the eye. They torqued down to spec, but were actually bottoming out in the crankshaft and not pressing against the flywheel hard enough to secure it while running. Never seen a Mopar without through holes on the crank flange.
[Re: A727Tflite]
#3171088
08/28/23 02:11 PM
08/28/23 02:11 PM
Posts: 43,335 Bend,OR USA
Cab_Burge
UPDATE! First, thank you to all who offered suggestions. This really had me stumped. Many of you mentioned the flywheel / flex plate. Below is a 2 minute video update showing exactly where the nose was coming from. https://youtu.be/GZzx_uC7blU?si=cxSEXEHNUw8upIj_For those who would prefer reading: The flywheel bolts (not converter bolts) ended up being too long, but long enough that it wasn't noticeable to the eye. They torqued down to spec, but were actually bottoming out in the crankshaft and not pressing against the flywheel hard enough to secure it while running. Never seen a Mopar without through holes on the crank flange. They were working on Chevy, probably didn't need to post it on here. I sincerely hope they repalced that flex plate, it had way much clearance and movement between the flexplate bolts bolt to flexplate fitment It should not rotate like it did
[Re: Cab_Burge]
#3171090
08/28/23 02:13 PM
08/28/23 02:13 PM
Posts: 9,587 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Id ask on a stockish looking build or parts, why not just use oem flywheel bolts vs aftermarket and costly. OEM stuff is pretty tough and proven.
STOP POTATO HATE!
[Re: Cab_Burge]
#3171128
08/28/23 04:33 PM
08/28/23 04:33 PM
A727Tflite
UPDATE! First, thank you to all who offered suggestions. This really had me stumped. Many of you mentioned the flywheel / flex plate. Below is a 2 minute video update showing exactly where the nose was coming from. https://youtu.be/GZzx_uC7blU?si=cxSEXEHNUw8upIj_For those who would prefer reading: The flywheel bolts (not converter bolts) ended up being too long, but long enough that it wasn't noticeable to the eye. They torqued down to spec, but were actually bottoming out in the crankshaft and not pressing against the flywheel hard enough to secure it while running. Never seen a Mopar without through holes on the crank flange. They were working on Chevy, probably didn't need to post it on here. I sincerely hope they repalced that flex plate, it had way much clearance and movement between the flexplate bolts bolt to flexplate fitment It should not rotate like it did Guilty as charged - not reading the first post.
[Re: BigDaddy440]
#3182894
10/10/23 09:07 PM
10/10/23 09:07 PM
Posts: 1 JACKSONVILLE
Pealer
JACKSONVILLE
Did the bolts solve the issue?? I've been following this thread for a couple weeks but just now registered to be able to see the replies, and I watched the vid and read the description. No idea if this is the issue I'm dealing with but it will be the first culprit once I get under the car to check things out. Thanks for the updates!!
