Oil preheater ? #315931
05/12/09 02:24 PM
05/12/09 02:24 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Just wondering what everyone uses. I have been using 2 moroso 400 watts pads but they are done. Is there a more economical route. 10 liters of oil doesn't heat up very quick with only 400 watts.
Re: Oil preheater ? [Re: mac56] #315932
05/12/09 05:10 PM
05/12/09 05:10 PM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
Have you ever tried a pair of block heaters?
Garth
Post deleted by Defbob [Re: Big Wedge] #315933
05/12/09 05:46 PM
05/12/09 05:46 PM
Re: Oil preheater ? #315934
05/12/09 05:49 PM
05/12/09 05:49 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Magnetic heaters work well on a steel pan.
Re: Oil preheater ? [Re: MoparforLife] #315935
05/12/09 07:42 PM
05/12/09 07:42 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Thanks for the links Fred and I have an aluminum pan so magnetic not going to do it. Thanks for the idea though.
Re: Oil preheater ? [Re: mac56] #315936
05/13/09 11:02 PM
05/13/09 11:02 PM
Down under
slantman Offline
slantman  Offline
Down under
I have a question regarding the stick on type oil heater pads, such as the Wolverine. Can the pad be removed once the oil has been heated, or do they stay stuck on the sump, and you just unplug it before driving?
Re: Oil preheater ? [Re: slantman] #315937
05/14/09 07:36 AM
05/14/09 07:36 AM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Moroso sells one that is a pad that is held on by springs but my thinking is it would not make as good of a contact with the pan to transfer the heat but I don't know anyone that has tried one.
Post deleted by Defbob [Re: mac56] #315938
05/14/09 07:38 AM
05/14/09 07:38 AM
Re: Oil preheater ? #315939
05/14/09 08:10 AM
05/14/09 08:10 AM
Salina ks
572_dup2 Offline
Back On The Bumper!!
572_dup2  Offline
Salina ks
I use the morosos one that is just glue to the bottom of the pan. It gets very warm. I have never took the temp gun an checked it though.
Shawn Jennings
Re: Oil preheater ? [Re: 572_dup2] #315940
05/14/09 08:27 AM
05/14/09 08:27 AM
DOUBLE 0 AND HOLDING THREE
BottomBulbRacer Offline
If you have the pan off, Moroso has a heater with an element and weld in bung that works excellent. Have them in a couple engines.
The pad with springs is for a dry sump tank.
Re: Oil preheater ? [Re: BottomBulbRacer] #315941
05/14/09 09:15 AM
05/14/09 09:15 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
How about just putting it inside your diaper?
Re: Oil preheater ? [Re: BottomBulbRacer] #315942
05/15/09 08:10 AM
05/15/09 08:10 AM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
I don't have the pan off but it is not a problem to remove. I looked at the internal element style. Do you just one per oil pan and do you feel they are more efficient than the pads?
Re: Oil preheater ? [Re: 572_dup2] #315943
05/15/09 08:15 AM
05/15/09 08:15 AM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
I have checked the temperature with a heat gun and on my 400 watt heaters and if I remember correctly they would be around 400 degrees on the bottom of the pad.
