Page 1 of 4 1 2 3 4
426 hemi mpg what are you getting in yours #31567
10/15/06 11:30 AM
10/15/06 11:30 AM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
I have just under 225 miles on the car so far. I didnt build it for fuel economy, but I thought it would be better than what it is. I am getting between 7-8 mpg out of the car so far. How you others doing with yours.
my set up is
426 siamese block
10.25 to 1 j and e piston
manely rods
eagle crank
426-2 indy intake
850 mighty demon
comp cams 508/519 235 at 50 mechanical cam
msd
2 1/8 hooker super comps
3 inch flowmaster exhaust
bowl and pocket work on the mopar aluminum heads
dana 60 with 3.54
4 speed
29.5x15.5x15 rear tire
2850-3000 rpm's at 70 mph
car weighs in at 3640 with a 1/2 tank
What do you think and how are yours doing. This is still a lot better than my max wedge was doing.
Re: 426 hemi mpg what are you getting in yours [Re: maxie] #31568
10/15/06 11:48 AM
10/15/06 11:48 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I don't think mine's ever done better than that, but in 20 years I've never really checked it; I just make sure there's gas available every 100 miles if it's going that far.
Mine's 438", 2x4 inline original carbs, 10.8:1, 260* @ .050, .565/.547 lift, 4-speed, 4.10, 27.5" tire, 3800 lbs, see Attachment. I generally keep it around 3000-3500 RPM but I have a rule that every time out, it sees full throttle at some point.
Re: 426 hemi mpg what are you getting in yours [Re: topside] #31569
10/15/06 12:05 PM
10/15/06 12:05 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you have to ask then you need to swap it for a leaning tower of power. That sounds like a normal milage figure for that engine.
Re: 426 hemi mpg what are you getting in yours [Re: topside] #31570
10/15/06 12:06 PM
10/15/06 12:06 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
we have twins.
Re: 426 hemi mpg what are you getting in yours [Re: maxie] #31571
10/15/06 12:19 PM
10/15/06 12:19 PM
Walla Walla, WA
Hemi_Jack Offline
Hemi_Jack  Offline
Walla Walla, WA
The best I've ever done with mine is 11.65 mpg cruising at 55-60. It usually gets about 9.6 on the highway. It depends on how many of the carbs I use! It is 10.5:1 has a torqueflite and 4.10 gears.
Re: 426 hemi mpg what are you getting in yours [Re: maxie] #31572
10/15/06 02:40 PM
10/15/06 02:40 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
7 or 8 around town and getting on it once in awhile is about right. With 3.54 or 3.23 gears I generally get 13-14 MPG on the highway with them.
Sheldon
Re: 426 hemi mpg what are you getting in yours [Re: RUNCHARGER] #31573
10/15/06 06:24 PM
10/15/06 06:24 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
That really isn't as bad considering that I rarely get more than 12 mpg around town in my 4.6 thunderbird.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: 426 hemi mpg what are you getting in yours [Re: AlexP] #31574
10/15/06 08:08 PM
10/15/06 08:08 PM
Millersville, PA
HemiChallenger Offline
Millersville, PA
about 7 give or take on the speed/rpm's.
Re: 426 hemi mpg what are you getting in yours [Re: HemiChallenger] #31575
10/15/06 08:21 PM
10/15/06 08:21 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
That's not that bad really. I estimate I only get about 9 or 10mpg with my small block.
Re: 426 hemi mpg what are you getting in yours [Re: maxie] #31576
10/15/06 08:28 PM
10/15/06 08:28 PM
across the river from Portland...
472 R/T SE Offline
472 R/T SE  Offline
OUt on the highway with an occasional romp I'm getting low 13's runnin' @ 3000-3200 rpm's.
I haven't checked around town yet.
[color:"purple"]HELP SUPPORT THE REGISTRIES.All cars matter.
1970 Charger Registry
I like to sleep For I'm walking in my dreams.
Live life like every DAY is your last!
Chrysler R/T Club
[/color]
Re: 426 hemi mpg what are you getting in yours [Re: 472 R/T SE] #31577
10/16/06 12:46 AM
10/16/06 12:46 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Back in 84 I Drove my 71 RT Hemi Charger 4speed 3:54 Dana from Chicago burbs to the Holiday INN at Indy, about 230 miles.. one tank of gas..
factory carbs, a little bigger cam..
Got to drive around the INdy 500 track that year...
Re: 426 hemi mpg what are you getting in yours [Re: maxie] #31578
10/16/06 02:09 AM
10/16/06 02:09 AM
Costa Mesa, California
michaelphbarnett Offline
Wait, shouldn't it be GPM?
Re: 426 hemi mpg what are you getting in yours [Re: michaelphbarnett] #31579
10/16/06 07:27 AM
10/16/06 07:27 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
You guys will probably call me a liar but years ago when I move back here I drove my Hemi GTX back following my wife. She drove 55 to 60 and I never got out of the back 2 barrels. I got an honest 19mpg. I had a mild hydralic cam in it, quick advance curve in the distributer, 2" headers, 4-spd, 3.54 gears, and LR60-15's. That's the only time I ever drove it that nice, it about killed me. Dave
Re: 426 hemi mpg what are you getting in yours [Re: quickd100] #31580
10/16/06 08:23 AM
10/16/06 08:23 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
I get alittle over 10 miles to the gallon
with crossram 770's, 410 gear, 31.5 tires,and
565 cam in a 70 cuda. That would be running 55-60
mph. If I run it hard maybe 5-6 mpg
logan426
Re: 426 hemi mpg what are you getting in yours [Re: AlexP] #31581
10/16/06 09:04 AM
10/16/06 09:04 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
My wife has a 2005 T bird. REally bad on gas, unbelievable!
Re: 426 hemi mpg what are you getting in yours [Re: Finoke] #31582
10/16/06 10:58 AM
10/16/06 10:58 AM
Dalton, MA
Slipknot440 Offline
Slipknot440  Offline
Dalton, MA
Haven't got the hemi done yet but the 440 in my 68 RR, auto, 3:91, bored 30 over, mild cam, 9:1 pistons, carter 750 gets about 14 at 70 mph.
I'm expecting 11 out of the hemi on the hiway
Re: 426 hemi mpg what are you getting in yours [Re: Slipknot440] #31583
10/17/06 12:42 AM
10/17/06 12:42 AM
Southern Michigan
Dartman440 Offline
Dartman440  Offline
Southern Michigan
I get 16 miles to the gallon in a 69 RR 472 Crate motor with a single 4 barrel and 850 Holley with a Keisler 5 Speed and a 4:10 rear doing 75MPH @2200 RPM.
Re: 426 hemi mpg what are you getting in yours [Re: Dartman440] #31584
10/17/06 08:33 AM
10/17/06 08:33 AM
Virginia
rm23j8g Offline
rm23j8g  Offline
Virginia
My totally stock 68 4 sp 3.54 geared RR gets around 11-12...doing typical to and from cruise duty in a suburban area. I drive pretty gently though..at least most of the time.
Incidentally, it gets better mileage than my 4 speed 3.91 geared AAR doing the same thing.
Re: 426 hemi mpg what are you getting in yours [Re: rm23j8g] #31585
10/17/06 09:21 AM
10/17/06 09:21 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Gas milage ??...gas milage ??...Hahahahahahah.. I supposedly have a big buck , 20 gallon Triangle MFG. tank, which only holds 18 gallon's ( they lied), From my house to Summit is 37 miles, it took alomost all 18 gallon's to get there. Probably had a quart to go.. I don't know..472, 10.5 to 1, 4.10's, 28" tall tire.I like to cruise at 3500 RPM..Single 1050 Dominator, and no, I didn't keep it on the "front" two the whole way there..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: 426 hemi mpg what are you getting in yours [Re: maxie] #31586
10/17/06 06:56 PM
10/17/06 06:56 PM
Raleighwood
2Bad360sfromNC Offline
Raleighwood
My 318 Challenger got about 7 mpg (the carb was junk) before I put the 360 in it. If you ever do get worried about fuel economy, I'll trade you the slant six out of my Valiant for your Hemi. It gets 21 mpg all day long in town.
1968 Charger project. I don't have a fender tag or a buildsheet, so it's getting a 440. Help me decide on a color--most everything looks great! (NOT white. My Challenger is white. Need some variety :D)
1974 Challenger 360
2012 Challenger R/T
1991 Dakota 5.2
Page 1 of 4 1 2 3 4
