Re: Challenger rear sway bar link substitute?
[Re: BDW]
#3158333
07/09/23 06:43 PM
07/09/23 06:43 PM
Posts: 21,430 It's a dry heat
gtx6970
It's a dry heat
70 Challenger rear sway bar:
I need to replace my rear sway bar links and bushings. I remember finding a substitute in the past, but can't find the info. I believe is was 68 or 70 Charger front sway bar links that are the same dimensions? Can anyone confirm?
Repo rears are available for $65, the Charger fronts are $10.
any aftermkt 68-70 B body links will work just fine
