426 Street Hemi intake manifold question ? #3158044
07/08/23 02:57 PM
07/08/23 02:57 PM
USA
DARTGTS340 Offline OP
USA
Anyone know the reason for the plenum notch under the primary bores of the rear (primary) carb?
Re: 426 Street Hemi intake manifold question ? [Re: DARTGTS340] #3158047
07/08/23 03:02 PM
07/08/23 03:02 PM
For drag racing 4 speed cars twocents
If your driving it on the street mainly don't do that tsk twocents
Re: 426 Street Hemi intake manifold question ? [Re: Cab_Burge] #3158050
07/08/23 03:07 PM
07/08/23 03:07 PM
USA
USA
No this notch or cutout is about 1/2 inch deep connection of the rear carb only primary bores and is on all stock factory street Hemi intakes. I tried to post up a picture but had an issue.
Re: 426 Street Hemi intake manifold question ? [Re: DARTGTS340] #3158057
07/08/23 03:24 PM
07/08/23 03:24 PM
That is used to have the same amount of vacuum to both idle circuits on the rear, primary, carb..
I thought you were referring to removing that divider all the way to the plenum floor like Mopar use to recommend for 4 speed drag cars, sorryblush
Re: 426 Street Hemi intake manifold question ? [Re: Cab_Burge] #3158063
07/08/23 03:35 PM
07/08/23 03:35 PM
USA
USA
Thanks!
Re: 426 Street Hemi intake manifold question ? [Re: DARTGTS340] #3158074
07/08/23 04:59 PM
07/08/23 04:59 PM
A727Tflite Offline
A727Tflite  Offline
Nothing to do with vacuum. EDIT. little to do with vacuum.
It was done to correct fuel distribution problems on cylinders 5 & 6.
Re: 426 Street Hemi intake manifold question ? [Re: A727Tflite] #3158077
07/08/23 05:17 PM
07/08/23 05:17 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Winner Winner, and from what I read Chrysler never got it right
Re: 426 Street Hemi intake manifold question ? [Re: cudaman1969] #3158122
07/08/23 08:30 PM
07/08/23 08:30 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Distribution seemed to be all over the place on mine, but likely aggravated by a pretty big cam profile.
We ended up with pretty much every corner being different, but after that it ran clean & mean.
Could arguably have been better with a single big carb, but I wanted a stockish look.
Re: 426 Street Hemi intake manifold question ? [Re: topside] #3158131
07/08/23 09:20 PM
07/08/23 09:20 PM
A727Tflite Offline
A727Tflite  Offline
There was three distinct “curves” for distribution depending on engine speed using the stock manifold.
Chrysler was locked in on the manifold design for 1966 due to planned launch dates.
I was always surprised they never did anything to further improve on that manifold design for the street.
Maybe subtle carb changes gave them what they needed.
Re: 426 Street Hemi intake manifold question ? [Re: A727Tflite] #3158137
07/08/23 09:52 PM
07/08/23 09:52 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The people who bought the Hemi didn’t care too much about running perfect as long as it did well with foot to the floor imo.
Re: 426 Street Hemi intake manifold question ? [Re: cudaman1969] #3158140
07/08/23 10:00 PM
07/08/23 10:00 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
There's truth in that - the thing was really happy wide open above 3500.
Idle & low RPM was pretty fat until my guru tweaked on the carbs.
Seems to me any 2x4 setup is a compromise at other than full throttle.
Re: 426 Street Hemi intake manifold question ? [Re: A727Tflite] #3158156
07/08/23 11:39 PM
07/08/23 11:39 PM
VA
dragon slayer Offline
VA
Do you have any technical notes on what the engineers were doing? I have wondered about the evolution of the carb jetting over the years. I get non emission/emission carbs, but Air bypass until 68, then some jet changes even on the 70 carbs.
Re: 426 Street Hemi intake manifold question ? [Re: dragon slayer] #3158158
07/08/23 11:58 PM
07/08/23 11:58 PM
A727Tflite Offline
A727Tflite  Offline
All I have access to is the 1966 Hemi Engine Development report/book.
And bits and pieces from discussions with some of the Chrysler engine guys back In the 60’s and 70’s.
Re: 426 Street Hemi intake manifold question ? [Re: A727Tflite] #3158444
07/10/23 08:56 AM
07/10/23 08:56 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I once saw what I assume was the first street hemi intake manifold. It was a work of art. It looked like a regular street hemi intake but was made out of steel tubing. Man those guys had fabrication skills. I guess this was used to test the idea on the dyno.
2011 Drag Pak Challenger
Re: 426 Street Hemi intake manifold question ? [Re: rickseeman] #3158447
07/10/23 09:16 AM
07/10/23 09:16 AM
A727Tflite Offline
A727Tflite  Offline
This one?
Re: 426 Street Hemi intake manifold question ? [Re: A727Tflite] #3158453
07/10/23 09:34 AM
07/10/23 09:34 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
No, this one was made out of steel tubing and of course covered in light surface rust.
Re: 426 Street Hemi intake manifold question ? [Re: rickseeman] #3158491
07/10/23 11:41 AM
07/10/23 11:41 AM
central il.
second 70 Online content
second 70  Online Content
central il.
The marine manifold has that on each carb?
Re: 426 Street Hemi intake manifold question ? [Re: second 70] #3158498
07/10/23 12:01 PM
07/10/23 12:01 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Yes, if I remember correctly the "marine" intake is similar to the 67 RO/WO and Vanke intake.
Re: 426 Street Hemi intake manifold question ? [Re: rickseeman] #3158521
07/10/23 01:22 PM
07/10/23 01:22 PM
A727Tflite Offline
A727Tflite  Offline
That is steel. Just painted. So you mean steel tubing, not steel sheet.
Re: 426 Street Hemi intake manifold question ? [Re: A727Tflite] #3158522
07/10/23 01:24 PM
07/10/23 01:24 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Yes, it was steel tubing, not fabricated. I was wondering how they got that tubing to bend so tight.
