Re: Small Block Magnum Engine Oil Cooler Kits
[Re: TheOtherDodge]
#3157884
07/07/23 08:05 PM
07/07/23 08:05 PM
Posts: 43,161 Bend,OR USA
Cab_Burge
Any suggestions on kits for this? Thanks! I'm getting ready to build a mild turbocharged LA360 stroker motor ( 3 3/4 inch stroke) with EFI and run E85 fuel with a Holley Dominator direct port EFI system, probably non inter cooled at first. My thinking is I will drill and tap the block oil filter outlet for a AN to NPT male adapter fitting, either #8 or #10 AN hose size, I will use a remote oil filter and thermostat for an oil cooler also in that system and another AN to what ever size the threads are for the oil filter adapter fitting that comes with all the L.A. blocks Wish me luck
[Re: Cab_Burge]
#3158073
07/08/23 04:56 PM
07/08/23 04:56 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Any suggestions on kits for this? Thanks! I'm getting ready to build a mild turbocharged LA360 stroker motor ( 3 3/4 inch stroke) with EFI and run E85 fuel with a Holley Dominator direct port EFI system, probably non inter cooled at first. My thinking is I will drill and tap the block oil filter outlet for a AN to NPT male adapter fitting, either #8 or #10 AN hose size, I will use a remote oil filter and thermostat for an oil cooler also in that system and another AN to what ever size the threads are for the oil filter adapter fitting that comes with all the L.A. blocks Wish me luck If the block will not be partially filled, no need for oil cooler, though it certainly won't hurt. My previous set up (Magnum series) was like that and never had an issue on 14 lbs of boost.
