Re: Need help i.d-ing connecting rods
[Re: WINGNUT]
#3157615
07/06/23 04:57 PM
07/06/23 04:57 PM
Posts: 3,089 Michigan
A727Tflite
NASCAR Hemi rods. OE. With SPS rod bolts.
Best rod we ever made at Chrysler. Heavy, but good.
Also had them in 6.96 and if I recall correctly 7.17” and 7.35”.
We spun these rods in a A and B/MP Hemi up to 8400 and never hurt the bearings or broke a rod. And that’s with a heavy piston back in the day.
[Re: WINGNUT]
#3157632
07/06/23 05:40 PM
07/06/23 05:40 PM
Posts: 4,694 Wichita
GY3
Wichita
So these rods are Chrysler OE? Will they work in a street 426 HEMI? The reason I ask is the person that bought them planned on putting a HEMI in his car. He purchased assorted engine parts and these were among them. Unfortunately he passed away, so I can't ask him. Are they desire able? Thanks for any input. WINGNUT They are old tech and worked at the time for what they were designed for. Much better and lighter options available today and no one see the rods in an engine so the value is negligible.
[Re: WINGNUT]
#3157646
07/06/23 06:28 PM
07/06/23 06:28 PM
Posts: 4,210 New York
polyspheric
New York
Requires a shorter piston compression distance, shorter stroke length, or both. $$$
Boffin Emeritus
[Re: WINGNUT]
#3157658
07/06/23 07:21 PM
07/06/23 07:21 PM
A727Tflite
So these rods are Chrysler OE? Will they work in a street 426 HEMI? The reason I ask is the person that bought them planned on putting a HEMI in his car. He purchased assorted engine parts and these were among them. Unfortunately he passed away, so I can't ask him. Are they desire able? Thanks for any input. WINGNUT Yes, made by Chrysler. They are heavy but they will last forever. Don’t worry about the weight. They will fit any RB or Hemi if you use the correct pin location in the piston. My suggestion is to see if the block you plan to use has been whacked on the decks. Back in the 70’s it was common practice to cut the deck .100”. Mock it up and calculate your CD required. Then look in your piston stash to see if you have what you need. I may have pistons that will work for you but I need to know more about your build.
[Re: A727Tflite]
#3157666
07/06/23 07:58 PM
07/06/23 07:58 PM
Posts: 9,534 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Sure they would work well but ask yourself why go to the expense of building around one outdated part just because you have it only to have a one off high bob weight custom assembly?
Anything can unexpectedly hurt a rod or piston then what?
Unload those puppies and buy a nice set of K1-s or such for your "street" hemi.
STOP POTATO HATE!
[Re: Mr PotatoHead]
#3157694
07/06/23 09:48 PM
07/06/23 09:48 PM
A727Tflite
Because he has them, if one or more gets wounded, there are plenty out there on the cheap. All else fails, replace them if they get wounded. Those rods will never fail on their own.
[Re: WINGNUT]
#3157701
07/06/23 10:03 PM
07/06/23 10:03 PM
Posts: 43,255 Bend,OR USA
Cab_Burge
What brand rod bolts and nuts? What size,3/8, 7/16 or ?
