Imitating Factory Cowl Pinch Weld Squeeze-Out #3157407
07/06/23 02:15 AM
07/06/23 02:15 AM
Cut and Shoot, TX
kentj340 Offline OP
kentj340  Offline OP
Cut and Shoot, TX
Looking for recommendations on what brand and type of caulk to imitate the squeeze-out on the firewall.
Also any pointers on technique.
Re: Imitating Factory Cowl Pinch Weld Squeeze-Out [Re: kentj340] #3157409
07/06/23 02:23 AM
07/06/23 02:23 AM
Cut and Shoot, TX
kentj340 Offline OP
kentj340  Offline OP
Cut and Shoot, TX
Also looking for recommendations on how to imitate what the factory called "dum-dum", the hand molded wads.
Re: Imitating Factory Cowl Pinch Weld Squeeze-Out [Re: kentj340] #3157410
07/06/23 02:34 AM
07/06/23 02:34 AM
California
sixpaktoogo Offline
sixpaktoogo  Offline
California
They can be made with POR15 two part epoxy putty. It dries hard just like the original material used to make the "wads,"
Re: Imitating Factory Cowl Pinch Weld Squeeze-Out [Re: kentj340] #3157832
07/07/23 04:09 PM
07/07/23 04:09 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
If you want it to look right, you need to be and think like a factory line worker.
Step 1: Get really wasted on Saturday and Sunday.
Step 2: Get very little rest for your 4:00 am start time.
Step 3: Apply the seam sealer in copious amounts. up whistling
I think the hardest part will be getting the right consistency of the sealer and amount so it will squeeze out. Maybe practice on a couple of pieces of metal to get a feel for those amounts.
My Monster are real!
Living within your means makes life pretty easy.
Re: Imitating Factory Cowl Pinch Weld Squeeze-Out [Re: 67vertman] #3157855
07/07/23 05:43 PM
07/07/23 05:43 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Honestly, I try like hell to not remove it, just try to prep for re-paint.
I'll leave factory paint runs in place, too, depending on the accuracy target for the car.
But yeah, a seam sealer that hardens, applied in a hurried/don't care manner. is pretty accurate.
