Oil pan gasket and/or timing cover leak? (440-3) #315684
05/12/09 02:00 AM
05/12/09 02:00 AM
Highland, CA
Mosin Offline OP
Mosin  Offline OP
Highland, CA
Hi All,
As you can see in the photos below, my 440-3 has a persistent oil leak in the vicinity of the passenger side oil pan/timing cover joint. I have tried and failed to stop the leak by redoing the oil pan gasket (5 times now! ) going from the Milodon to Mopar and now and Felpro #1834 oil pan gaskets. I have tried them dry and with Right Stuff around the front to no avail. I had a metal shop flatten the flanges twice, and am currently running a Felpro #1834 dry (i.e. without any sealant) as depicted below.
Having failed to stop the leak via the oil pan gasket, and studied its growth/path several times, I'm now wondering if the problem is the upward deformation of the "stiffening plate" at the bottom of the timing cover on the passenger side, which is where the oil seems to be emerging. Because there isn't a bolt to cinch that reinforced portion of the timing cover straight down to the oil pan, you can see in the photos that the gasket is not compressed there as it is along the front and sides. I was thinking about pulling the oil pan again and trying to bend the lower timing cover down on the passenger side to see if that provides a more solid mating surface with the oil pan gasket, but I thought it would be a good idea to check in with Wiser Minds around here and share the photos before making the leak even worse!!
TIA for any tips/suggestions!
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: Mosin] #315685
05/12/09 02:02 AM
05/12/09 02:02 AM
Highland, CA
Mosin Offline OP
Mosin  Offline OP
Highland, CA
I wanted to provide another angle of the leak. I hope that's OK with the Mods!
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: Mosin] #315686
05/12/09 12:14 PM
05/12/09 12:14 PM
Highland, CA
Mosin Offline OP
Mosin  Offline OP
Highland, CA
Any thoughts on my idea to try bending the lower timing cover plate down on the passenger side? Assuming the PO or their mechanic/s repeatedly used a screwdriver on that side to remove the oil pan, I'm hoping to close the gap (so to speak). Also, is anyone running a Felpro 1834 dry, or should I be using some sealant around the front as well? Thanks!
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: Mosin] #315687
05/12/09 12:39 PM
05/12/09 12:39 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
The proper fix would be to drop the pan. Check the rail for straightness. Bending it up doesn't seem like a bad idea from your pictures storey but I'd think straight should do it.
For a driver type of repair if you don't feel like dropping the pan. A mini C clamp or drill a hole and then run a nut and bolt through there.
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: Mosin] #315688
05/12/09 01:05 PM
05/12/09 01:05 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'm going to guess either the t-chain cover or pan is bent. Drop the pan and check the the cover w/ a straight edge, then take a look at the pan rail. It also appears you have a windage tray is that thing nice and straight?
Coming soon!!!!
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: Mr.Yuck] #315689
05/12/09 01:12 PM
05/12/09 01:12 PM
Danville, NH
Mopar_Mike Offline
Mopar_Mike  Offline
Danville, NH
Do you have leaks anywhere else? I am only asking because I did my pan over 2-times and did the timing cover over 2-more times only to have the same leak in the same spot as yours. I also had valve covers leaks. The light bulb went on when I saw a bubble come out the valve cover leak.. That told me it was pressure slipping past my gaskets. I added an e-vac system and all the leaks went away. My two cents would be to check your PCV. Don't just assume a couple breathers will do the trick, make sure you have a good ventilation system. Good luck.. leaks suck..
RS23L7 4-Speed
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: Mopar_Mike] #315690
05/12/09 01:22 PM
05/12/09 01:22 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
good point. I've seen valley pans pop up like jiffy pop because the engine had no way to vent.
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: Mosin] #315691
05/12/09 02:05 PM
05/12/09 02:05 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Is it me or is that a CHROME timing chain cover ?
But yes bend that back down , if it's chrome you want to grind off the chrome and use a sealant on the gasket , both sides .
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: JohnRR] #315692
05/12/09 02:47 PM
05/12/09 02:47 PM
Highland, CA
Mosin Offline OP
Mosin  Offline OP
Highland, CA
Many thanks for the responses!
The timing cover is stock (i.e. not chrome) and there is no windage tray. Having Gunked the oil off several times and watched the leak grow I am sure it isn't coming from the VCs or the upper timing cover seal where it meets the block. Additionally, I had a metal shop straighten the pan rails and am using slightly oversized washers to create a better contact.
The passenger side PCV checks out A-OK (it's new) and I also have a breather on the passenger side VC. (Note: I don't have any VC leaks, but the driver's side VC doesn't have any breather or venting...just the twist-on cap. Is this a problem?)
Re. the idea to use a c-clamp or drilling a new hole for an additional nut/bolt to cinch the stiffening plate down to the pan rail on the passenger side, I was considering this, but seeing the amount of leakage I think I'm going to have to drop the pan again and try some sealant around the front lip. I have been using Gaskacinch (no love) and Right Stuff (even less love as it's 5x as expensive and still didn't work). Does anyone have a different product to suggest that has worked for them, or should I just go for the Right Stuff again after straightening the bottom of the timing cover down?
Thanks again!!
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: Mosin] #315693
05/12/09 11:24 PM
05/12/09 11:24 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Hylomar
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: Bill MeLater] #315694
05/12/09 11:44 PM
05/12/09 11:44 PM
colorado
chargermop Offline
chargermop  Offline
colorado
its the timming cover its bent by the pin you can see it in the pic... been there.....
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: chargermop] #315695
05/12/09 11:58 PM
05/12/09 11:58 PM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
Most of the time I find the oil leaks are from around the bolts. Try removing the bolts one at a time and RTV'ing the inside of the head.
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: Bill MeLater] #315696
05/13/09 01:24 AM
05/13/09 01:24 AM
Highland, CA
Mosin Offline OP
Mosin  Offline OP
Highland, CA
Thanks for the tip! I'm assuming the Permatex Blue/Hylomar version is the same thing? (there's some conflicting info out there on the Internets re. Hylomar in UK vs. USA).
My plan of attack tomorrow will be to clean of the oil once again and try a c-clamp on the pss side lower timing cover/pan joint. If that stops the flow, I'll drill a strategic supplementary bolt hole and be done with it...perhaps redoing the oil pan seal with Hylomar along the front if necessary. With my luck, that won't work and I'll be doing the entire cover, but it's worth a try! Thanks again for the responses.
PS Tried sealing the bolts with Right Stuff already but it didn't work. <==20W-50!
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: Mosin] #315697
05/13/09 09:03 AM
05/13/09 09:03 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
No reason to add the bolt if just straighten out the timing cover ???
Also are you SURE your fuel pump is not the leak point , but it's easy to see the timing cover is bent , I'm surprised it leaked after you gobbed it with RTV ???
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: JohnRR] #315698
05/13/09 09:09 AM
05/13/09 09:09 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
easy enough to find out, go buy some dye at the parts store and run it then check it.
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: Mosin] #2131338
08/12/16 06:02 PM
08/12/16 06:02 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Old Thread
Same Exact Area
Have The Timing Chain Cover Off Now
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: bee1971] #2132021
08/13/16 02:52 PM
08/13/16 02:52 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Originally Posted By bee1971
Old Thread
Same Exact Area
A quick phone call could have saved you the time of searching this out.
Free tech advise when using our products wink
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: Mosin] #2132065
08/13/16 03:44 PM
08/13/16 03:44 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
We had a job come through the shop a few years back that was very similar. It has been to a few different shops that had done pretty much what you describe.
We thoroughly degreased the area with brake clean till it was squeaky dry. We started the motor and let it run for a bit with no signs of leakage. We then took it for a short test drive up and down some hills at normal in town speeds. Still no sign of a leak. PUZZLING??? We then took the motor up to about 3000 RPM in neutral while observing the area. After about 1-1/2 to 2 minutes oil began to appear at the RF corner. The source of the leak was the balancer seal. It would dribble down onto the lip of the pan gasket and the air movement from the fan would push it to the RF corner, around the corner and then down the pan rail. At a casual glance one assumed it was the pan gasket timing cover but it was not whistling
As previously suggested make sure it's not the fuel pump, it's gasket, or the pipe plug for the fuel pump pushrod.
beer
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: Mosin] #2132341
08/13/16 10:50 PM
08/13/16 10:50 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Road Hazard I sent you a PM
Peace Scott
TJP
Great advice , Thank You
Fuel pump gasket and pipe plug look spotless
Honestly my engine is very clean
Anyways going to order a new reproduction timing chain cover , don't like the look of the factory 45 year old original , especially that bottom flange
Install a new seal
New gaskets
And then re install oil pan and go from there
It really looked from what I saw before ripping it apart , was coming from the area of the larger bolt on the front bottom corner of timing chain cover , passenger side timing chain cover gasket right above oil pan
I have owned this car since 1984 when I was in high school
Rebuilt the numbers matching motor give or take 20 years ago
Forget what I have actually done over the years
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: bee1971] #2132552
08/14/16 10:28 AM
08/14/16 10:28 AM
moparx Offline
moparx  Offline
this may, or may not be something for you to think about. i had a leak on a big block one time that gave me fits coming from the front as you describe. finally pinned it down to the damper seal. changed the seal after inspecting the damper surface to be sure it wasn't affecting the leak in any way. back together and it still leaked, so the first thing i thought of was the spring came off the lip of the seal. everything back apart and all looked good. then a guy older than me stopped by when i was scratching my head and suggested i drill out the locator pin holes on the front cover to the next size, install the cover loosely, install the damper to center the seal, then tighten up the cover bolts. that did it ! even using the same seal. i do that now on all front cover installs, and the seal issue hasn't came back since. just my experience i'm passing on.
beer
