Thanks Wes! I enjoyed the experience and always loved the writeups from MoparBilly, Jeff and Joel!
That's only 1240lbs heavier than my Road Runner.
Only a little over a half ton heavier.
Looking at the videos, I think I can tighten the rebound up on the front shocks some on the nitrous passes, it's bouncing a little which seems like wasted energy. I don't know if that'll be worth anything in ET, but the rear looks great so I can try working on the front.
I also am hoping the rear springs are going to settle a bit more with use. Worst case, believe I can change just the rear segment on the monoleafs to get it an inch lower.
