Source for this wire connector #3154245
06/25/23 09:43 PM
06/25/23 09:43 PM
Someplace you aren't
SomeCarGuy Offline OP
This is on a 69 b body with AC fan resistor. The resistor failed and melted the connectors. I have the ones for a single wire, but not sure where to find this one for two wires.
I want my fair share
Re: Source for this wire connector [Re: SomeCarGuy] #3154253
06/25/23 10:21 PM
06/25/23 10:21 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Digikey or Mcmaster-Carr twocents
Re: Source for this wire connector [Re: SomeCarGuy] #3154273
06/25/23 11:50 PM
06/25/23 11:50 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Looks like this but you may need it for 12 or 10 gauge wire to use it for two wires? You might try here? : https://www.amazon.com/Baomain-Female-Terminals-connector-insulated/dp/B01M33TF8K
Re: Source for this wire connector [Re: A12] #3154274
06/26/23 12:09 AM
06/26/23 12:09 AM
You’re right, one for a bigger wire might due if these aren’t available anymore. It looks different than the other ones that came off.
Re: Source for this wire connector [Re: SomeCarGuy] #3154277
06/26/23 12:38 AM
06/26/23 12:38 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
With the right pick tools, needle nose pliers and a little patience I bet you could save that one you have.
Re: Source for this wire connector [Re: SomeCarGuy] #3154279
06/26/23 12:42 AM
06/26/23 12:42 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Heat or "burn" the insulation away and while it's warm those tabs should bend a little easier and there may even be a little room to get a pick tool under the first crimps with the insulation melted?
Re: Source for this wire connector [Re: A12] #3154286
06/26/23 05:18 AM
06/26/23 05:18 AM
It might salvage. If one could be had quickly I thought it would be simpler. Have lots to do before the show.
Re: Source for this wire connector [Re: SomeCarGuy] #3154372
06/26/23 01:54 PM
06/26/23 01:54 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
That is just a standard Packard terminal. Used extensively. Probably could pick up a few at a local auto parts store. Or here, https://ceautoelectricsupply.com/individual-components/connectors-and-plugs/packard-connectors/
Re: Source for this wire connector [Re: SomeCarGuy] #3154484
06/26/23 07:25 PM
06/26/23 07:25 PM
Jefferson State
srt Online content
ESYC
srt  Online Content
ESYC
Jefferson State
Re: Source for this wire connector [Re: srt] #3154521
06/26/23 10:08 PM
06/26/23 10:08 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
Evans wiring, Bill had plenty, I bought them last year at Carlisle. evenswiring.com
Re: Source for this wire connector [Re: srt] #3154527
06/26/23 10:53 PM
06/26/23 10:53 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Originally Posted by srt
Re: Source for this wire connector [Re: srt] #3156090
07/02/23 12:04 AM
07/02/23 12:04 AM
Re: Source for this wire connector [Re: SomeCarGuy] #3156399
07/03/23 03:20 AM
07/03/23 03:20 AM
Jefferson State
srt Online content
ESYC
srt  Online Content
ESYC
Jefferson State
Re: Source for this wire connector [Re: srt] #3156755
07/03/23 11:03 PM
07/03/23 11:03 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
What size are the wires? If its 14 AWG, then a 10 - 12 AWG lug would be a perfect fit. If its a 12 AWG, then a 10 AWG lug is a little small, but you would probably be ok.
I have a lot of experience with industrial lugs. We do have some cases that we put two wires into a single lug - put the proper circular mills/area of the wires in the lug and you will be fine. A 14 AWG stranded wire is around 4100 circular mils (cm). 12 AWG is 6500 cm and 10 AWG is 10,400 cm. So that is why a 10 - 12 AWG lug would be a perfect choice if the wires are 14 AWG and it would be a little small if the wires are 12 AWG.
I personally don't think that is a 2 wire lug. I think what looks like a 2 wire lug is actually the crimp method used. I think finding an appropriate crimper would be your most difficult issue. But I could be wrong and it might be a 2 wire lug, but that would not be my first guess.
