Re: BS23R0B315070 - sketchy HemiCuda
[Re: Alaskan_TA]
#3156223
07/02/23 01:48 PM
07/02/23 01:48 PM
Posts: 1,114 Rochester NY
Jer
Rochester NY
Hopefully the buyer can get his money back & if not, he can sue the seller. Why? The primary info was disclosed, the seller has a record of the restoration and most likely a known past, and I have to assume that anyone who can lay down $200k probably had someone look at the car before purchase. Let's be honest, this car was not purchased because of it's 'investment grade'; that possibility was eliminated with the restamps and non-original drivetrain. I think it's disingenuous to keep assuming there's 'fraud' involved at every level, and lawsuits are the way to handle disagreements on 'originality'
[Re: lakerism]
#3156352
07/02/23 09:52 PM
07/02/23 09:52 PM
Posts: 1,754 Phila
PhillyRag
Phila
I thought replacing or even removing the VIN was a felony, period. According to some it can't even be "touched". Just think: It's attached to a foam/vinyl dash pad, which is only screwed onto a metal frame, which is then bolted onto the car's steel structure. Seems the automaker made it really easy to "move" it as needed. So if you remove the dash pad from your car, you broke the law?
[Re: PhillyRag]
#3156600
07/03/23 03:29 PM
07/03/23 03:29 PM
Posts: 21,406 It's a dry heat
gtx6970
It's a dry heat
[Re: PhillyRag]
#3156613
07/03/23 04:46 PM
07/03/23 04:46 PM
Posts: 32,924 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
I thought replacing or even removing the VIN was a felony, period. According to some it can't even be "touched". Just think: It's attached to a foam/vinyl dash pad, which is only screwed onto a metal frame, which is then bolted onto the car's steel structure. Seems the automaker made it really easy to "move" it as needed. So if you remove the dash pad from your car, you broke the law? Only if you put the VIN tag on another car.
[Re: stumpy]
#3156721
07/03/23 09:44 PM
07/03/23 09:44 PM
Posts: 10,201 Someplace you aren't
SomeCarGuy
I thought replacing or even removing the VIN was a felony, period. According to some it can't even be "touched". Just think: It's attached to a foam/vinyl dash pad, which is only screwed onto a metal frame, which is then bolted onto the car's steel structure. Seems the automaker made it really easy to "move" it as needed. So if you remove the dash pad from your car, you broke the law? Only if you put the VIN tag on another car. Now now, don’t spoil the vin swappers spin to make themselves feel better. Taking things way away from reality to distract from what they are doing.
I want my fair share
